Sunroof Leaking
Old Nov 24, 2014 | 09:51 AM
Knighted's Avatar
4wd High
Default Sunroof Leaking
My newly acquired 2008 LR2 has a roof leak that I suspect is coming from the sunroof. I've repaired the sunroof drain on my Disco 2 before, but I took a look at the sunroof from the roof yesterday and can't really tell where the drains are to see if they are clogged. Can someone point me in the direction to where I can find them? Also any information on the common causes of LR2 sunroof leaks. I won't be able to remove the headliner for a couple of weeks, so I'm hoping it's simply a clogged drain.
If someone could take a picture of the front portion of their sunroof with the roof open from the top, that would be a great help too. When I have my sunroof open from the top I am able to see exposed headliner near where the sunroof track recesses into the roof, any help would be appreciated. Thanks.
Old Nov 25, 2014 | 07:16 PM
LR2driver's Avatar
2008 LR2 with approx 80K miles. Shown from top with sunroof open. Note that I had my sunroof glass tinted so it appears darker than original glass.
Attached Thumbnails Sunroof Leaking-lr2-sunroof-1.jpg   Sunroof Leaking-lr2-sunroof-2.jpg   Sunroof Leaking-lr2-sunroof-3.jpg
rally1
Feb 22, 2022 06:22 AM
kseasley
May 3, 2010 06:45 PM
geoffthepoolguy
Feb 19, 2010 04:28 PM
Kent Green
Nov 5, 2008 04:30 PM
crainface
Oct 29, 2008 06:25 AM
