Electrical issues after rain storm
Old Jul 14, 2011 | 06:34 PM
Manicoti's Avatar
7th Gear
Default Electrical issues after rain storm
First off, thanks for the help i've received in the past. I'm technically challenged and am unable to contribute much here. But if you ever need help on drums (the musical instrument) i can help
Last night, my 2006 LR3 was parked outside during a heavy heavy wind and rainstorm. When i went outside this morning, probably a good couple of hours following the storm, i noticed both front and rear wipers were going at full speed. Inside the car, the nav system was going off and on along with the radio and the interior light was on. The key was NOT in the ignition and wipers are off. In order to get it to stop, i have to put the key in and turn it to the first detent. The wipers stop but the nav, radio and interior lights stay on. I can turn the radio and light off but the nav stays on.
The seat was a little wet and the floor on the drivers side was also wet but nothing else seemed wet. My wife left the sunroof open to the vent setting where it only lifts an inch or so. It wasn't so wet that i couldn't sit on the seat without getting wet. I checked the inside fuse box and there is no signs of precipitation at all or anywhere near there.
I disconnected the battery but when hooked back up and the key out, the same thing happens. I could hear the 2 wiper relays clicking away when the key is out and the wipers going without them being turned on. I tried to pull the relay out but the black cover came off and the relay stayed in and i could see the inside of the relay clicking away. This is the fuse box under the hood. The cover seemed to be on properly and again, no signs of precipitation on or around the fuse box.
I drove it for a couple of hours and everything works perfectly it's only when the key is out. After an hour and a half drive, i took the key out and nothing happened. I waited a few minutes and it appeared to have worked itself out but 10 minutes later, it happened again and this time the alarm was going off because i had locked the door.
Could it be the ignition and maybe it got a little wet?
Any suggestions??
Thanks,
Mark
Old Jul 14, 2011 | 08:21 PM
Rovin4life's Avatar
pull out the fuse box underneath the passenger side footwell and clean everything of water. if its all corroded then its ruined and you need a new one that has to be programmed by the dealer. you probably have a sunroof drain leak or an apillar leak.
ellebarto
Sights N Sounds
Aug 23, 2014 08:44 AM
jna97
Oct 1, 2012 02:18 PM
Chris-bob
Off Topic
Sep 8, 2011 01:44 PM
dgelfuso
Dec 24, 2010 02:33 PM
SmooveB23
Nov 11, 2007 08:33 AM
