Suspension / Sunroof Issue
Old Dec 13, 2011 | 11:09 PM
ians65's Avatar
5th Gear
Default Suspension / Sunroof Issue
I purchased a off-lease 2006 LR3 in Nov 08 and have had minimal issues until recently. I searched the site and did not see much on these topics so thought I would see if this forum has any ideas before I head off to the dealer or mechanic.
I'm in the Los Angeles area and have typically gone to the dealer, since its out of warranty now I'd like to look at going to an independent. Any recommendations?
Suspension (Access/Normal Only)
I'm able to lower the vehicle but unable to to raise it for off highway mode. I have no fault messages. When in Access mode, the switch does not allow me to raise to Normal. I have to drive and then vehicle raises automatically to Normal.
A few months ago I did noticed that when I would go in off highway mode the front would not raise at the same time. One side took a few seconds longer to level off. Air suspension problem?
Sunroof Stuck in Tilt Mode
The sunroof is stuck and I checked the fuses and found that there are no issues. It seems that it may either be the switch or motor and understand the headliner has to come out to determine what the issue is.
Any guidance would be appreciated.
Thanks
Old Dec 14, 2011 | 06:20 PM
hell pie's Avatar
Regarding the sunroof, have you tried a reset? Hold the close button for 20 seconds and the sunroof should spring to life.
Old Dec 14, 2011 | 08:52 PM
ians65's Avatar
5th Gear
Thanks. The sunroof reset worked.
Old Dec 15, 2011 | 08:28 AM
Rovin4life's Avatar
The switch is bad, trust me seen it a few times too many. Too many people spill coffee and such on it.
Old Dec 21, 2011 | 03:07 PM
socalrovershop's Avatar
suspension issue could be as easy as a compressor not putting out enough pressure. just did 2 last week for a similar issue. the sunroof needs to recalibrated. if your looking for a shop feel free to give us shout i service plenty of cars from the LA area i actualy have one in the shop right now that got towed in from a dealer. www.ragingbull-performance.com
fastrx7man
Jan 28, 2012 12:49 PM
mrb06lr3hse
Mar 11, 2011 01:36 PM
BigRed98
Jun 21, 2010 12:30 AM
ja00disco2
Sep 21, 2009 08:24 AM
TrickyWhu
Mar 9, 2007 11:38 AM
