Recommended Factory Maintenance?
Old Sep 4, 2011 | 09:49 AM
MichaelMaxim's Avatar
5th Gear
Default Recommended Factory Maintenance?
Does anyone have a link to the factory recommended maintenance intervals for the LR3?
What about timing belt replacement for the 4.4L in a 2007?
Old Sep 4, 2011 | 11:02 AM
Rovin4life's Avatar
4.4 petrol doesn't have a timing belt. The diesel does. Its every 7,500 miles oil changes with 5W30 synthetic and outside of a rotation and pollen filter every 15k the air filter isnt changed till 60k and the TC and the Electronic rear diff is changed at 75k.
Old Sep 4, 2011 | 01:32 PM
5th Gear
Well that's good news. Is changing the diff fluid and t-case fluid like it is in a NP241 Jeep t-case or a Dana 44? Just pop the cover, inspect for metal shavings, drain the fluid, clean it out with brake cleaner and refill?
Or is it a bit more than a typical fluid flush in a domestic vehicle?
Old Sep 4, 2011 | 03:15 PM
Rovin4life's Avatar
absolutely not, You only change the rear diff at 75k if it has a rear electronic diff. But you remove the drain and let it drain out and then fill it up with special fluid. its special fluid that comes from the dealer.
Old Sep 7, 2011 | 12:25 PM
socalrovershop's Avatar
how many miles on your lr3 ? i have the charts for the services
ghinesley
Dec 19, 2021 03:50 PM
tjhappel
Feb 20, 2011 07:54 PM
jpperry
Oct 27, 2008 09:44 PM
DDLR3
Jan 6, 2008 08:35 PM
rover2003
Dec 8, 2007 08:40 AM
