pulls to the right
Old Jan 7, 2011 | 04:36 PM
dragan's Avatar
Default pulls to the right
My LR3 05 pulls to the right when I travel at low or high speeds.I have new tires and have had a front end alignment and new both lower control arm replaced. So what could be wrong?
Old Jan 15, 2011 | 09:52 AM
jimbiram's Avatar
Check tire pressures, and recheck the alignment. Not everyone knows how to do a proper 4 wheel alignment on the LR3. Also, you might try rotating the tires. I have had bad tires installed that cause that as well and you may have to have it "trued".
Old Jan 21, 2011 | 03:08 PM
Manicoti's Avatar
7th Gear
Mine was like that when i test drove it and part of the deal was for them to align it before i picked it up. They did and it was even worse!
I bought it at a ford dealership, when i went and picked it up the second time, it was bang on.
Apparently they had to do the alignment with the door open so the truck would stay at the higher suspension level vs when it comes down after the truck is turned off.
Andy2Rover
Sep 11, 2014 06:30 AM
idahorover
Jun 26, 2011 07:18 AM
Garrett
Nov 6, 2010 11:02 PM
sforb
May 2, 2009 06:38 PM
