Optima batteries worth the extra $?
Old Jun 16, 2010 | 09:41 AM
pilsner's Avatar
Default Optima batteries worth the extra $?
I dont know if this is the correct section for this post but oh, well, if its not then someone will move it for me.
Question: Is the OPTIMA batteries worth the extra $100 over a normal store brand battery in our rovers?
I am not currently running many extra (lights, winch, etc) but plan to add some as finances allow and I do go offroading a LOT. Are store brand batteries that prone to failure from moisture or vibration that I should consider that as a buying criteria?
thanks
brian
Old Jun 16, 2010 | 10:15 AM
d2luvr's Avatar
All those accessories pull lots of amps and at idle your alternator only puts out so much juice, so your battery has to feed them. When using something like a winch it can discharge your battery very fast, even with the engine running. Most batteries don't like this 'deep cycle'. Optima and some of the other high end batteries are not prone to failure when deep cycled repeatedly. Another thing to keep in mind is that most people that run a winch also run dual batteries for this reason.
Old Jun 19, 2010 | 04:45 PM
RTTOY's Avatar
I had a yellow top for 4 years, ran a 9500lb winch, rocklights...you name it. Paid $140 at the time, parted out the rig and still got $100 for it. They are good batteries, I've heard bad things with the red tops but have no experience personally with them.
Old Jun 19, 2010 | 06:24 PM
Rovin4life's Avatar
or you could always run a deep cycle battery for the winch to the back its alot less cheaper.
Old Jun 20, 2010 | 07:12 AM
Some people have had issues on and off in the past, I run dual Yellow Tops and swear by them, not at them. If you are looking at some pulling power for a winch, these or the new Sears deep cycle batteries made by Odessey are the way to go.
jordamf
Jul 21, 2011 09:31 AM
krazzz
15
Nov 4, 2010 06:23 AM
Street Wolf
13
Apr 21, 2009 03:04 PM
seamuspg
Apr 17, 2009 05:30 PM
jdelp
Mar 12, 2008 11:02 AM
