oil leak
Old Mar 26, 2010 | 03:55 PM
lawson's Avatar
Default oil leak
have oil leak on front hub running down tyre and inner sheild could this be oil seal if so are they difficult to change its a 2.5 tdi as this the first 4x4 i have had
Old Mar 26, 2010 | 04:11 PM
What year, does it have swivel ball or is it a D2?
Old Mar 26, 2010 | 04:43 PM
lawson's Avatar
its a 1997 and it does have swivel *****.
Old Mar 26, 2010 | 04:58 PM
OK, so where exactly is the leak coming from, from the seal between the axle tube to the swivel or a swivel seal?
Either way, you are probably going to need to order a complete seal kit for both sides as well as bearings if you are over 100,000 and haven't kept the bearing cleaned, repacked and torqued properly.
Old Mar 27, 2010 | 03:02 AM
lawson's Avatar
not sure were the leak is coming from going to jet wash down today if it is the seals are they difficult to change and are they expensive,keep you informed thanks for advice mike going to buy a manual today
Old Mar 27, 2010 | 06:59 AM
Don't buy a manual before you down load a free copy of a Rave CD, use the link in my signature section.
If you still need help shout. Also Only go to a place like Atlantic British or Rover Connection for the complete seal kit and bearings if needed. Make sure you use the new 1 shot grease packets when refilling the swivels.
Old Mar 27, 2010 | 03:16 PM
lawson's Avatar
thanx for info down loaded manual gonna order seals and bearings from where you suggested it is coming from ball coupling but the one seems abit pitted so going to order second hand one let youknow how i get on thanxs
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
