Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Modifications
Register Forgot Password?
Old 01-11-2009, 03:41 AM
Junior Member
Default converting from Air suspension to coil spring, ple help
Hi all, I'm thinking of converting the air suspension on my 01 disco to a coil spring. Any advice on what the disadvantages are? what effect will it have on the truck? will I still be able to maneuver it the way I used to. Any advice will be appreciated from the experienced people. Thanks.
Old 01-11-2009, 09:29 AM
Send a message via Skype™ to Disco Mike
Default RE: converting from Air suspension to coil spring, ple help
Why would you want to remove such a good and comfortable feature???????????????????????
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-11-2009, 10:08 AM
Junior Member
Quote:
ORIGINAL: Disco Mike
Thanks Mike.
Part of what I really want to know is why you call it good and comfortable feature.
This thing is really frustrating, It goes down virtually every time I park the car, sometimes it goes up as soon as I start the truck, and sometime it doesn't. Is it normal for it to go down when I park?
I really need to understand the advantage of the air spring over the coil spring so that I will know what I stand to lose (if any) if I decide to convert to coil spring.
Old 01-11-2009, 11:58 AM
Maybe a more important issue for you to look at is why is it acting up and how come you haven't asked for any help to fix it.
__________________
Mike
Need Parts?
Old 01-11-2009, 01:17 PM
Junior Member
I have before now, i guess i didn't ask correctly. Pls help. guide me how to trouble shoot it. Thanks in anticipation.
Old 01-11-2009, 03:39 PM
Send me your tele number, I'll call you and we can work thru it.
__________________
Mike
Need Parts?
Old 01-24-2009, 04:45 PM
Junior Member
To answer your question the work involved is not difficult. Get rid of the air suspension. The coil conversion is a good setup. I have dealt with air suspensions from motorcycles to custom cars and in time note that they all fail due to cracks in the bladder(air bags) or faulty lines.
Old 01-25-2009, 08:33 AM
Just for what it is worth, everything fails some more freuently then others. Yes air bags can crack with time, no big deal, springs and coils drop with age, shocks fail as do bushings.
The fact that your motor cycles and custom cars have had failures has absolutely nothing to do with a Disco's set up that will give you years of good servive and a great ride before needing some maintance.
__________________
Mike
Need Parts?
Old 02-11-2009, 11:24 AM
Junior Member
i just sent my '99 disco series two to the dealer to fix exactly that problem. i was also thinking of doing the coil spring conversion. on the other hand i like the comfort of the air. i wouldn't mind a more experienced opinion on that myself.
Old 11-11-2010, 12:53 AM
Junior Member
Quote:
Originally Posted by dapo View Post
Thanks Mike.
Hi there, Just to give more information and share what i recently discovered. The main advantages of air spring over the coil are:
1. Variable Load-carrying capability
2. adjustable spring rate
3. user-friendly height control
4. low friction action
Source:http://www.firestoneindustrial.com/p...ng%20works.pdf
Tags
2007, air, coil, conversion, convert, disco, forum, lr3, range, rear, rover, spring, springs, suspension, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
