Up-grade to electric fans....
Old Nov 27, 2010 | 07:41 PM
mydisco03's Avatar
Default Up-grade to electric fans....
Hi there, I need to know the normal tempeture on a bosh 4.6 litres engine. I just up-grade to electric fans but the a/c fan kick in around 208 and bring the temp down to 203. but when i turn the a/c the temp climb to 220 or more.... i just need to know the normal temp on this motor..... thanks
Old Nov 28, 2010 | 02:35 AM
mydisco03's Avatar
Umm, no one know????????????
Old Nov 28, 2010 | 10:15 AM
You have cost your self some big BUCKs for nothing.
Why did you change your fan, how many miles on your truck and what was the truck running at before you decided to do this.
You, by your temp numbers are now running way too hot./ Your t/stat starts to open at 180 and is fully open at 192, I rarely get above 204 or 205 even when driving in the mountains.
Old Nov 28, 2010 | 11:53 AM
mydisco03's Avatar
Mike: The day before i did the electric fans I decide to plug my obd2 scaner to see the working temp in the motor, so i went for a long drive and stop on a 711 to get some drinks and left the engine running for about 10min, no more than that, came back and check the temp and it was at 220 already on my obd2 creen, but on the dash board fine. So I taw it was normal since the truck has never over heat on me, So the next day I did my electric fans and went out for a test drive and notice my temp 210, 212, 215 On trafic, but on hig way went down quick to 195 around 70miles, also notice the a/c fan kicking in around 208 so that's when I started to ask my self that 212F and up was no normal... So I decide to check the radieator for mud and dirt and find out it was super dirty. Now I clean the radiator and the temp dont pass over 204 in traffic..... This is a Discovery 2003 with 120k.... The reason I did the up-grade was to gaing some power since i'm running 35" tires.... I did the exhaust str8 with cat, mantec and knn air filter plus the electric fans and the truck gaing the power BaCK..... So at the end Mike what you think??? I'm still watching the temp with the scaner =D and going to keep doing this for a cuple of days untill im sure 100%
Old Nov 28, 2010 | 12:01 PM
mydisco03's Avatar
I order a new t/ stat from Atlantic british, bcz this one was leaking and look like no one has never change it before..
Old Nov 28, 2010 | 05:04 PM
First, do your self a huge favor and get rid of that K&N air filter before it costs you a new MAF as well as a really dirty engine.
Your numbers are way to high and I would suggest you go see a radiator shop and see what they suggest as to possibly cleaning out your radiator.
How is your new fan set to come on, is it mutiple speeds and at what temp?
Old Nov 28, 2010 | 07:19 PM
mydisco03's Avatar
Maf sensor is about a year old, and knn is about 8mo Thanks for the advice................. The a/c fan kick in around 208f while the aditional electric fan turn on around 204f plus the fan cluth is back on the truck, the temp still high, but it stay around 204 and the maximum is 208 no more than that.... Yea the new t /stat get here on tuesday and i'm hooping to solve the problem...So far the oil is fine and im not loosing any coolant at all, so the engine still ok. I'm cheking with a radiator shop on wednesday to see what they said afther i swap the new t/stat... Thanks Mike!!!
Old Apr 12, 2011 | 03:23 PM
mydisco03's Avatar
Well, Letme just re-post on this issue....... I found out that my radiator is clug on the inside and don't think I can fush it... So the truck still running hot but never went to 220F againg since I clean the out side of the radiator with alot of water and a flash light to see if the light go tru the other side....
Francopacks
Aug 10, 2012 08:39 PM
03discoman
May 10, 2010 05:10 PM
kenk
Aug 19, 2009 08:25 PM
wilson96rr
May 31, 2009 10:07 PM
mitsi88
May 7, 2009 08:57 PM
