Grade 8 nut on a grade 5 bolt. No no?
Old Aug 10, 2012 | 04:23 PM
Francopacks's Avatar
Default Grade 8 nut on a grade 5 bolt. No no?
Am I nuts (hehe) putting a grade 8 nut on a grade 5 bolt? I'm replacing the nuts on my front drive shaft because they are getting stripped, but I can only find grade 8 nylock nuts in a fine tread in my area.
Old Aug 10, 2012 | 05:58 PM
antichrist's Avatar
From boltscience.com
Is it okay to use a mild steel nut with a high tensile bolt?
Nut thickness standards have been drawn up on the basis that the bolt will always sustain tensile fracture before the nut will strip. If the bolt breaks on tightening, it is obvious that a replacement is required. Thread stripping tends to be gradual in nature. If the thread stripping mode can occur, assemblies may enter into service which are partially failed, this may have disastrous consequences. Hence, the potential of thread stripping of both the internal and external threads must be avoided if a reliable design is to be achieved. When specifying nuts and bolts it must always be ensured that the appropriate grade of nut is matched to the bolt grade.
The standard strength grade (or Property Class as it is known in the standards) for many industries is 8.8. On the head of the bolt, 8.8 should be marked together with a mark to indicate the manufacturer. The Property Class of the nut matched to a 8.8 bolt is a grade 8. The nut should be marked with a 8, a manufacturer's identification symbol shall be at the manufacturer's discretion.
Higher tensile bolts such as property class 10.9 and 12.9 have matching nuts 10 and 12 respectively. In general, nuts of a higher property class can replace nuts of lower property class (because as explained above, the 'weakest link' is required to be the tensile fracture of the bolt).
Old Aug 10, 2012 | 08:39 PM
I googled that for hours earlier today and didn't come up with nearly such a definitive answer. You do good work!
comleader
Jan 6, 2014 06:56 PM
focusontheworld
Oct 21, 2012 01:00 AM
nynole
Feb 19, 2009 01:11 AM
xb70valkarye
Appearance & Camping Set Ups
Aug 25, 2006 01:28 PM
disco1
Nov 21, 2005 10:19 PM
