Self Installed Lift
Old 12-27-2014, 12:58 AM
LRlax11's Avatar
Default Self Installed Lift
What are your guys' opinion on putting my lift kit on my disco 2 myself? Any warnings or things I should watch out for?
Old 12-27-2014, 10:51 AM
cosmiccharlie's Avatar
Go watch lucky8's videos. It is fairly easy if you have any mechanical skill. Took me only about 2 hours.
Old 01-04-2015, 06:31 PM
gpete's Avatar
Use your bottle jack to increase the distance between your frame and axle to install the taller springs.
Old 01-28-2015, 11:22 AM
Flyhighdp's Avatar
Default Lift Choice?
what lift did you go with? before/after pics?
Thanks
Old 01-28-2015, 03:17 PM
swak6287's Avatar
I had put on many lifts from Explorers to Jeeps, and now to my Disco, all at my driveway. Jackstand, common sense, muscles, and bottle jack. That is all u need, and have fun
Old 01-29-2015, 11:48 PM
cybercop's Avatar
Be ready to do more than coils and springs. I have a wandering effect I still haven't gotten rid of.
Going to try castor correcting arms next.
Old 01-30-2015, 08:47 AM
swak6287's Avatar
I will drop it off to be aligned after that.
Old 01-30-2015, 09:31 AM
drowssap's Avatar
i spring compressor will make things go easier also, the spring fit in without force and you do not have to disconnect the sway bars.
Old 03-05-2015, 04:26 PM
kingsly's Avatar
+ 1 on this. I've done lifts solo on two discos and can do all four corners in ~2hrs. Just get the frame solidly on jack stands and use the factory bottle jack between the axle and the frame to push the axle down away from the spring perch. It would definitely go smoother if you disconnect the sway bar - but I've never bothered.
frankie_500 (03-10-2015)
Old 03-10-2015, 01:30 AM
frankie_500's Avatar
I'm no expert but you definitely have to consider having stuff like a heavy duty floor jack (can withstand at least 3 tons), jack stands, and breaker bars to add leverage. If you don't have enough time to do it in one day, you will need ample garage space. Lots of sites that can guide you step by step. It would be good if you ask friends to come over and give you a hand. Good luck!
Spencerfitch
02-10-2017 10:57 AM
AK Rover
12-05-2016 03:39 PM
caymandrew
05-09-2015 10:05 PM
LRlax11
04-26-2015 08:01 AM
jdhuegel1
03-01-2011 08:26 AM
Quick Reply: Self Installed Lift
