Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
would a paxton blower work good for a freelander?
Old Mar 5, 2005 | 01:35 AM
05LandRover's Avatar
Default would a paxton blower work good for a freelander?
would a paxton blower work good for a 2.5 gas freelander?
Old Mar 18, 2005 | 05:38 PM
Patrick's Avatar
Default RE: would a paxton blower work good for a freelander?
for an application like that, i would recommend checking with paxton....they would know exactly what items of theirs will work with...
Old Apr 16, 2005 | 03:44 AM
since a freelander is basically an x type, i'm thinking that if i put the x type intake and cams, etc on there, it would run a little better. freelander 2.5 = 174 hp, x type 2.5 = 192 hp
Old Oct 30, 2005 | 09:46 AM
DiscoMike's Avatar
Banned
The freelander has a very sophisticated 4WD system compared to the Jag. I wont go into details, but the freelander looses a lot of power through this whole system, each bit sapping a little power, but all these little bits add up...
And also, the freelander and Ja are very different vehicles, the Jag, a motorway cruiser. The freelander, an off roader. The engines may well be almost identical, but the landy needs lots of low down torque for going off road whereas the jag doesnt, so it can afford to sacrifice low end torque for high end power!
I agree the cams and intake may be different, but the biggest difference is most likely to be the EMS, which controls all the fuelling etc.
Old Oct 30, 2005 | 12:12 PM
hell, i'll just drop a small block ford 302 in it and that bitch will haul ***. jk
that would be a hard job to complete, but interesting to see.
Old Oct 17, 2007 | 02:40 PM
ajh's Avatar
ajh
If you consider anything in a freelander it should be to replace your head gaskets with full copper gaskets to prevent the very common engine destruction caused when the stock gaskets fail and fill the oil with coolant. Adding more pressure to the mix is probably a bad idea. Just bore and stroke it at the same time.
Old Dec 20, 2007 | 08:30 PM
sideburns's Avatar
really those motors are a bad egg to start with,adding a supercharger would just send it over the edge,not to knock your car or anything
Old May 2, 2008 | 02:46 PM
unstable's Avatar
I'd suspect that it'd be more than just a bolt-on-and-go affair.
Usually when you're talking about forced induction, you need to look at the compression ratio of the current piston/combusion chamber combination. If your compression is already semi-high, adding a supercharger is a disaster waiting to happen.
Old Feb 28, 2014 | 07:36 AM
The_OGCJR's Avatar
I thought that engine was the same V6 as the Ford Escape. If that is true, that engine should be solid enough to take a mild boost. @6psi or less. It would be the same engine as the Contour V6's, Same block as the SVT Contour. Ford has been using it for many years.
Old Feb 28, 2014 | 09:27 AM
It's not the same
Savannah Buzz
Jan 12, 2015 03:33 AM
team_lunatics
Freelander
Sep 24, 2010 12:08 PM
jtb
Aug 2, 2010 03:17 PM
fire1427
May 20, 2007 12:46 PM
eric2
May 28, 2005 02:44 AM
