Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
rebuilding turbo on 2015 RR evoque 4 cyl
Old Dec 16, 2022 | 02:54 PM
earlyrovertoo's Avatar
5th Gear
Default rebuilding turbo on 2015 RR evoque 4 cyl
My 2015 RR evoque has its original Turbocharger. Everything works just fine, as it should, but eventually when the Turbocharger dies, I would like to rebuild it. IF you are experienced along this line, may I ask a few things: 1. I imagine rover turbo in evoque has quality ball bearing on its shaft, can they be pressed out; new bearings pressed in? Other than seals, etc., what else needs to be changed in restoration of unit? Overall, your thoughts on restoration of Rover Turbo? Thank you.
Celal cinaar
Range Rover Evoque
Dec 30, 2023 12:38 PM
Martyn Singleton
Range Rover Evoque
Apr 16, 2021 03:54 AM
rangeroverman
Range Rover Evoque
Feb 24, 2018 02:34 PM
Matthew German
Range Rover Evoque
Jan 21, 2017 08:13 AM
js8488
Range Rover Evoque
May 17, 2014 10:40 AM
