2002 hse rr a/c problem
Old 05-07-2010, 03:49 PM
bobco's Avatar
Default 2002 hse rr a/c problem
hi, my 2002 hse has a problem with the a/c. It starts out fine and real cold and and as soon as the cab reaches right temp the compressor I think doesnt cycle back on,and yes to stupid book symbol appears. My a/c guy said its got enough refrigerant he emptied it once and measured and said it was right were it should be he thinks the compressor clutch might be going bad he suggests tapping it with a stud to see if it starts doing it again. (it wont quit cycling on when he checks it out)any ideas of what else it might be.
Old 05-07-2010, 08:09 PM
wilson96rr's Avatar
Well, The first thing you need to do is pop the hood when it does it and see if the compressor is turning. If not, then tap it with something to see if it engages. Be careful. If it does, you probably just need to remove a shim from the clutch or you may need a new clutch as your mechanic said. Another issue could be improper voltage to the clutch. Easy enough to check with a volt meter. Another could be a bad relay that engages the clutch. Try swapping it out. If the compressor is turning, my guess is that the sensor inside the vehicle that controls the temp is bad. Hope that helps you out. My guess is that it is the relay.
Old 05-08-2010, 12:12 AM
bobco's Avatar
thanks, wilson 96. I'll pass that on to my ac mechanic, sound very logical. I love this forum and and good contributors like you. bobco
Old 05-09-2010, 11:23 PM
LRScott's Avatar
The clutch like wilson stated, is known for going out due to age and use. When you are diagnosing this, do not use the "AUTO" function on the HVAC controls. Ensure that the "a/c off" light is not illuminated and set both temp zones to "lo". There is the possibility that your 3 way pressure switch is going bad. Basically, if the compressor is getting the correct voltages, it is most likely the clutch. If it is no longer getting any voltages, it is probably the 3 way pressure switch. There is the possibility the HVAC ecu/control panel is going bad, but I doubt it.
Old 05-10-2010, 06:15 AM
Rovin4life's Avatar
How about checking the codes in the HVAC system. If you ac mechanic was so smart that would be the first thing he would have done.
Old 05-11-2010, 05:22 AM
wilson96rr's Avatar
I think you need Testbook or equivalent to check HVAC codes.
Old 05-18-2010, 09:48 PM
skyguy's Avatar
Yes you do the code readers wont read those codes unless you get the big money one from AB
bavarian_range89
01-19-2008 02:10 AM
JimMayor007
12-05-2007 08:46 AM
BridgeRover
08-31-2007 09:13 PM
artcareer
08-13-2007 04:24 PM
sback1
12-09-2005 12:40 PM
Quick Reply: 2002 hse rr a/c problem
