Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 11-07-2011, 06:40 PM
Junior Member
Default 2006 HSE EAS problem
looking for some info on my sister's HSE...it has a suspension fault. the rear will raise and lower normally via the dash switch, but the front is stuck in the raised position. Even driving down the road, over 30mph the front will not return to "normal" position. thanks for any assistance.
Old 11-07-2011, 07:42 PM
Senior Member
Take a look at the height sensors on the front, its possible they are either damaged or installed in correctly. if they are not, then look at the connectors for damage and if that is good, have the codes read to see which one is actually bad.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 11-07-2011, 08:18 PM
Junior Member
kool, thanks for the quick reply. will report back tomorrow.
Old 11-08-2011, 01:38 AM
LRScott's Avatar
Senior Member
This may or may not help. RangeRovers.net has a nice detailed site for common problems with your style Rover. A lot has changed since the 03 models though... There was a little paragraph in the EAS section about an issue like this. Hope this helps!
Front/Rear Imbalance
Earl Thiel reports: "My '03 Range Rover from the beginning (I now have 43k mi) has had a problem with the EAS in that it will intermittently raise the front of the car and not the rear. No idea why. Could be parked-I get in and start and it will pop up-leaving the rear down so the car appears to "squat". At the dealership now for the fourth time to try to get them to fix this problem. Their latest idea is to replace all 4 height sensors. Upon measuring, the front end has over 2 inches greater clearance than the rear when this phenomenon occurs." This problem can be caused by excessive pressure in the system leading to premature failure of the rear air bags. A service campaign was undertaken (April 2003) to address this by installing a pressure relief valve (MAV500010K) between the compressor and the air tank on vehicles 3A101029 to 3A106310. However, this valve in turn could cause its own problems -- see above.
Came from this site: http://www.rangerovers.net/rrmkiiire...tml#suspension
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 11-08-2011, 01:28 PM
Junior Member
thanks for the info, gonna get it on the lift this afternoon and check the sensors...and i'll look for the valve.
Old 11-08-2011, 11:39 PM
Senior Member
possible cross link valves not operating properly not venting the front air springs
Old 11-16-2011, 10:05 PM
Junior Member
just to follow up, it turned out to be bad front height sensors. thanks for the help!
Tags
03, 2006, air, common, front, hse, imbalance, pressure, problems, range, rear, relief, rover, rovers, suspension, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
