How to change the front air spring with HD photos (2003 -)
Old Apr 24, 2015 | 10:41 AM
daxter1987's Avatar
Default How to change the front air spring with HD photos (2003 -)
I recently changed the front air spring on a Range Rover and wanted to share the procedure with photos for anyone tackling the job. Any questions or comments to improve please share!
Link: Land Rover Help!: How to change the front air strut on your Range Rover (2003 and up)
Old Apr 24, 2015 | 02:46 PM
drowssap's Avatar
Thx
maybe one of the mods could make it a post in for the RR Section
Old Apr 24, 2015 | 05:37 PM
threalassmikeg's Avatar
Nice writeup!
Just a FYI. the new Voss fitting stays in he strut. all you need do do is remove the old hardware, then simply insert the air line into the new fitting, making sure it is fully seated.
Cheers
Old Apr 26, 2015 | 11:50 AM
daxter1987's Avatar
Thanks! I'm not sure I understand what you mean by the new boss fitting stays in the strut. I followed the instructions that come with the strut and it says to take it out... ??
Old Apr 30, 2015 | 05:55 AM
Ok. The fitting itself is called a Voss fitting. You didn't do anything wrong by removing it and installing it on the air line.
On photos #9 and 10 in your write up you will see there is a white plastic plug in the fitting that is in the strut.
All you need to do is remove the plug, and push the air hose into the fitting, it will push in and lock on the ferrull.
collin Barrows
Aug 28, 2011 07:13 AM
catchthebig1
Sep 24, 2010 11:57 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
FordCrusherGT
Jan 10, 2007 02:15 PM
