How to change the front air spring with HD photos (2003 -)
I recently changed the front air spring on a Range Rover and wanted to share the procedure with photos for anyone tackling the job. Any questions or comments to improve please share!
Link: Land Rover Help!: How to change the front air strut on your Range Rover (2003 and up)
Ok. The fitting itself is called a Voss fitting. You didn't do anything wrong by removing it and installing it on the air line.
On photos #9 and 10 in your write up you will see there is a white plastic plug in the fitting that is in the strut.
All you need to do is remove the plug, and push the air hose into the fitting, it will push in and lock on the ferrull.
daxter1987
LR2
Nov 6, 2014 02:33 PM
collin Barrows
Aug 28, 2011 07:13 AM
catchthebig1
Sep 24, 2010 11:57 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
FordCrusherGT
Jan 10, 2007 02:15 PM
