Radio Antenna - 2000 Range Rover 4.6
Old 02-01-2010, 08:58 AM
JStephen's Avatar
Default Radio Antenna - 2000 Range Rover 4.6
I am installing Satellite Radio and i'm having trouble locating where the antenna is in the truck so i can install the FM transmitter? Any ideas where this is located?
Old 02-01-2010, 10:55 AM
LRScott's Avatar
Should be in one of the side windows in the cargo area. Can't remember which one...
Old 02-01-2010, 11:30 AM
handsome rob's Avatar
My satelitte radio has the FM transmitter inside the unit and I just pick which frequency I want from the menu, then I pick it on the radio and it works.
Is that the antena that you are talking about or are you talking about the satelitte reciever antenna?
Old 02-01-2010, 01:03 PM
JStephen's Avatar
The old sat radios had a very strong FM transmitter signal. The new ones are dummied down & you have to install a wire near the trucks antenna. Its annoying. I have had Sat. Radio for a long time now. The older ones were a lot stonger than the new ones.
Old 02-01-2010, 06:24 PM
wilson96rr's Avatar
I use the cassette adapter and just leave it plugged in. I ran the wire from the sat radio unit to the cassette deck behind the radio console for a clean look. I couldn't get the fm frequency thing to sound very good. It sounds a lot better running through the cassette deck.
Discochic
11-30-2010 02:13 PM
ainiguez
05-18-2009 09:39 PM
charlesrbaker
11-07-2008 01:08 PM
Spike555
06-21-2008 09:17 AM
HerbD
06-14-2006 02:52 AM
Quick Reply: Radio Antenna - 2000 Range Rover 4.6
