If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
I recently purchased a 1999 Range Rover. Shortly after, I noticed that there was water leaking on my foot by the brake pedal, whenever I had the AC on. Now, the AC does not work at all. I am wondering if anyone has an idea as to what could be the problem/how to resolve it. Thanks!
The water leaking is probably from the a/c drains being plugged up. However, are you sure it is water and not coolant? Water from the a/c is usually leaked from the passenger side when the drains get clogged. BTW, what country are you in, and is your rover a gems or bosch model?
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Scott, SAME DEAL with my P38 on the drivers side and ALWAYS wet, PLUS the thing over heats at the drop of a hat EVEN with a new Radiator, thermostat and water pump all installed by the dealer.
Is that water from the HEATER CORE?
Also on Subject, when the P38 starts to get to hot the A/C quits and blows HOT.
__________________
Take Care
George Pavlisko
Aiken S.C. or Orange Park Fl.
Some of the STUFF
Rovers
1998 D1 50th MJ
1996 D1 (stray) (Got parts)
2001 Range Rover 4.6 HSE ALIVE AND WELL with a new Heart
2005 LS3 SE (wife) Her CAR not my wife.
1978 Rolls Shadow II (will restore)
1971 "E" type Jag 2+2 V12
1984 Porsche 928
1937 Chevrolet Modified
2003 50th Anniv Corvette
1992 S10 Blazer Sport 78,000 original miles.
Condenser fan working?
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
If the moisture on the floor is coolant, then yes it is definitely the heather core. If the o-rings are bad, coolant will seep out. However, it overheats so the core might be old and clogged up too. Here is the replacement procedure, I haven't done this myself, but it looks pretty straight forward: Heater Core Replacement (Range Rover 4.0/4.6/P48)
As for the a/c going out, it could be for a number of reasons. My condenser fans almost never come on, which is pretty typical on P38s. The cause of your the issue is probably sensor related. You can override the automatic system by moving the temp down to "LO". If that does not turn it back on, then you now know its not the interior temp sensor. It could also be possible that it is turning off the a/c to protect your engine from overheating. Running the a/c compressor with an overheating prone P38 is just asking for it.
__________________
Have you checked your hoses for gunk? Its odd that your overheating with a new radiator, water pump, and thermostat. What thermostat are you using? I use a 180 in mine. The dealer recommended that I use a195, well with a 195 and a new radiator and fan clutch I overheated, went above 9 o'clock and I just about flipped out. With a 180 even on the hottest days I am just fine.
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
