ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
runaway rover
Old Dec 23, 2010 | 04:31 PM
NiteTrain's Avatar
Default runaway rover
guy on the jeep forum was looking for a rover video
"The vehicle was on it's side, and about 20 locals were "helping" trying to flip it back on it's wheels. When they finally succeeded, you see no one set the brake and the vehicle goes rolling down the hillside and crashes like you'd see in a cartoon. "
i didn't find it but i found this..crazy
[youtube]http://www.youtube.com/watch?v=5zx3qKX_Pno[/youtube]
Old Dec 25, 2010 | 09:32 AM
safarisam's Avatar
Another Defender a victim to the oil cooler lines.
Old Dec 25, 2010 | 07:36 PM
hilltoppersx's Avatar
guess no one had a f'n extinguisher...
Old Dec 26, 2010 | 11:29 AM
NiteTrain's Avatar
I don't understand..how is the oil getting into the combustion chamber from the cooler lines?
Old Dec 27, 2010 | 06:55 PM
safarisam's Avatar
What? Do you want a full explanation of the oil flow in a rover v8?
Old Dec 27, 2010 | 08:26 PM
Spencerfitch's Avatar
I know the exact video your talking about. mexicans flip the truck off its side and it rolls off a clif.
Old Dec 27, 2010 | 08:31 PM
antichrist's Avatar
It doesn't have anything to do with oil cooler lines. It's more than likely from a blown turbo allowing the engine to suck crankcase oil in to the combustion chamber (could have been something else allowing lube oil in, but that's the most common scenario).
A reason to install a emergency air shut-off.
I think maybe you're thinking of this video of the runaway Land Cruiser. (I can't find the one without the half-assed commentary)
http://www.youtube.com/watch?v=nxXrAym93Wc
Old Dec 27, 2010 | 08:33 PM
so its running? And why are they letting it?
Old Dec 27, 2010 | 08:53 PM
antichrist's Avatar
Once a diesel starts sucking oil in to the combustion chambers they are difficult to stop.
If it's a manual gearbox (and you can get to it through the smoke) sometimes you can get it in to gear and stall it, provided you can anchor is against something. Brakes alone wouldn't be enough.
Shutting off the air supply is the best way.
http://www.amotusa.com/Z_Dead%20Datasheets/4261.asp
Old Dec 28, 2010 | 09:20 AM
safarisam's Avatar
Antichrist notice I said rover v8 and oil cooler lines have been a huge cause of engine fires with American bound v8 defenders
