RE: aftermarket stereo in LR3
I basically added a new stereo system minus the speakers. The equipment I added gives me the option of using my factory system or the stereo I installed. Read my only other post, it should help you out. If you happen to take the route I took you'll be able to add alot more equipment then I did. The main component of my system is the Kenwood KOS-V500. Kenwood also has a newer version out, I believe it's the KOS-V1000, Do a little research on that.. Hope I helped.
__________________
05'Zambezi silver Lr3 SE V8, R.I.P. 00' SE Black Disco II
