Sights N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Land Rovers, Range Rovers, and Freelanders.
rover on the Rocks 3
Old Nov 18, 2011 | 07:45 PM
Fivespddisco's Avatar
Default rover on the Rocks 3
This is the official Rovers on the Rocks top 3 in each class.
Open Class
1st Michael Widener D2
2nd Frank Padavan D90
3rd Jonathan George D110
Expo Class
1st Charles Galpin D90
2nd Jake Hartman D1
3rd Trevor Griffiths D1
And a quick highlight video from the event. Enjoy
Rovers on the Rocks 3 highlights - YouTube
Old Nov 21, 2011 | 05:27 PM
honda50r's Avatar
Were lockers allowed?
Old Nov 22, 2011 | 11:39 AM
Danny Lee 97 Disco's Avatar
I have another question regarding the off-roading. You commonly see Rovers with a wheel completely up in the air a few feet off the ground. I do not recall seeing any other vehicles that seem to do anything similar to that. Is it due to the boxed frame?
Old Nov 22, 2011 | 11:43 AM
devildog01's Avatar
Yes they were.
Old Nov 23, 2011 | 11:38 AM
Long Haul's Avatar
I think its mostly a balace thing with these trucks is why youll see one tire in the air. Im not sure the exact specs but say a D1 is 60/40 (60% front 40% rear) a regular pickup truck mite be 70/30 (its gonna keep the front planted on the ground). The radius arms really hinder articulation in stock form, heim jointed instead of factory bucshings would drastically improve travel. With that said if I have a tire in the air with my setup I'm probably on the side or on the roof.
Old Nov 26, 2011 | 08:04 PM
Jake1996D1's Avatar
I agree with Brian..... And it also has to do with flex in the rear too. most people run +2 shocks and maybe cranked arms. D2's are limited by watts, and if you're running sway bars at all then you're gonna have some wheels in the air. It take quite a bit of work to get the a d1 to flex enough to keep all 4 on the ground at all time. and it takes even more with d2.
With that said I dont have the flex ***** Brian has with the 3 link and 12" fox shocks all around. Soon to be coil over set up but I've done a good job of keeping all 4 on the ground.
Here's a couple pics some of the guys took of my truck at ROTR - decent suspension + Detroit/TT and engaing cdl on last hill = a debateable 2nd place
Old Nov 27, 2011 | 07:56 AM
hilltoppersx's Avatar
Don't start that d2s are limited by watts bull****. you can compare stock trucks but you can't compare modified rigs. If my d2 had a 4link it could out flex a stock freelander is point that is null.
Old Nov 27, 2011 | 04:51 PM
Jake1996D1's Avatar
I'll out flex you fool
Fivespddisco
29
Nov 15, 2011 10:50 AM
Fivespddisco
Nov 5, 2009 08:56 PM
Fivespddisco
Aug 29, 2009 08:13 PM
LambChop
Mar 31, 2009 03:10 PM
rover2003
Dec 9, 2007 09:06 AM
