Suspension sponsored by Arnott Inc. Talk about your suspension within.
Locking the suspension
Old Dec 3, 2007 | 10:53 AM
jjballer1's Avatar
Default Locking the suspension
How do you lock the suspension for when you want to change a tire or change the brakes or something like that?
Old Dec 3, 2007 | 11:10 AM
ajh's Avatar
ajh
Default RE: Locking the suspension
You don't. You can probably block it to prevent it from lowering but unless you disturb one of the height sensors (Disco) it won't lower.. usually. There is a company who makes a manual way to inflate the suspension that would work I guess.
Old Dec 3, 2007 | 11:24 AM
jjballer1's Avatar
so how do you change your tire without risking messing up the suspension?
Old Dec 3, 2007 | 12:50 PM
llesra's Avatar
in a p38 you leave the tailgate open to lock the suspension. lift the truck under the axle to change a tire/brakes
Old Dec 3, 2007 | 01:59 PM
jjballer1's Avatar
Does that almost work when I bring it a mechanic and they want to put it on a lift machine?
Old Dec 3, 2007 | 03:28 PM
cuda's Avatar
in the lr3 . i remember just putting it in offroad height .then holding the switch untill you hear a chime...i believe a light will come on in the dash.
after fighting the air suspension for 20 min, i had to do what no man should have to do to change a tire...USE THE MANUAL !
Old Dec 3, 2007 | 04:43 PM
llesra's Avatar
tell them to use floor jacks and not the lift. locking the suspension only works when the vehicle is on the ground.
Old Jan 4, 2008 | 10:03 AM
If you are worried about picking up a D2 with SLS, don't worry.
I lift mine all the time, sometimes the suspension will settle sometimes not, but as soon as you put it back on the ground it will reair back up.
Old Jan 14, 2009 | 09:47 PM
carlitonsky's Avatar
And what about a LR3, how do i change the tires ,etc ?
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
Aaron Sandland
Feb 12, 2015 09:35 AM
fastrx7man
Jan 28, 2012 12:49 PM
johanba
Apr 3, 2007 11:37 AM
