Suspension sponsored by Arnott Inc. Talk about your suspension within.
Water in compressor motor and head
Old May 2, 2008 | 08:04 PM
fireboat's Avatar
Default Water in compressor motor and head
I have a 2000 Discovery 2 that I just got with a sagging rear end. I talked to DiscoMike who gave me some suggestions to track the problem down (much thanks!). However, I was surprised to find that the real problem was a lot of water inside the compressor head and motor. Apparently, water entered through the breather tube that goes to a canister on the frame rail.
The canister and tube looked intact without any cracks.
What would cause water to get in here? Is there some sort of check valve?
I took the motor and compressor apart but it was totally full and had been for some time. I will see if I can dry it out and get it working. If not I will go to roverland parts. But I don't want this to happen again which is why I am trying to figure why it happened in the first place.
Thank you.
aftermath431
Nov 19, 2013 09:59 AM
focusontheworld
Sep 12, 2012 12:23 PM
me 2
Jun 17, 2012 07:24 PM
