Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
They rub!
Old Nov 11, 2007 | 06:23 AM
ScottinNJ's Avatar
Default They rub!
I got a heck of a deal on very lightly used 265/60 18 Yoko Geohandlers. After doing research on this and the main site, I thought for sure I would be clear as I have stock 18s but and truck was converted to coils. (I heard they only rub in access height...not a concern for me.) They look outstanding. It turns out the rub sometimes when I take turns going into and out of my drive. I removed the front mud guards, but didn't have a chance to drive it yet. I hope this helps with the rubbing.
Old Nov 11, 2007 | 09:01 AM
dirtyduk's Avatar
Default RE: They rub!
scotttinNJ, I'm no positive but look at your steering knuckles,I think the p38's also had steering stops like the older cars,an adjustable bolt that restricts the movement of the knuckle,if your axel has them . you can make a small adjustment to keep the tires from rubbing, note that it also reduces your turning radius.
Old Nov 11, 2007 | 06:56 PM
ScottinNJ's Avatar
Thanks Dirtyduk. I took the truck for a spin today and I think removing the front mud guards did the trick.
By the way, where in NJ is your shop located? You've been so helpful to so many of us, I would love to return the favor by using your shop.
As always, thanks for your input.
Zonk872
Oct 27, 2011 01:52 PM
kato disco
Mar 8, 2011 03:06 PM
oysterhead
Dec 30, 2009 05:32 PM
oysterhead
Aug 23, 2009 10:19 PM
RoverDude420
Nov 18, 2005 01:02 AM
