Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Disco II tires
Old Dec 28, 2007 | 12:29 PM
tlester72's Avatar
Default Disco II tires
I was wondering what is the largest tire i could put on my 2000 Disco II without a lift. I would also appreciate info on where i could find a 2" lift and info on how hard they are to install.
Old Dec 28, 2007 | 04:09 PM
Default RE: Disco II tires
What size wheels are you running, what are you using the truck for and if alot of off road what type of trails?
Old Dec 28, 2007 | 04:58 PM
tlester72's Avatar
I have 16" wheels and i dont do a whole lot of off roading, some but nothing extreme.....YET !! I really want something that looks good and if i do decide to go off roading that will hold up well. But unfortunatley most of my driving is on the road. I am thinking about putting as 2" lift on it in the near future.
Old Dec 29, 2007 | 07:58 AM
put the lift on first so if you go to a larger tire it will fit.
If you are not going to a lift, look at a 245/75/16 as about the tallest tire you can go to without rubbing.
Old Jan 2, 2008 | 10:41 AM
tlester72's Avatar
Thanks i appreciate all of the info. If i am going to install a 2" inch lift , what size would you recommend going with then?
Old Jan 2, 2008 | 08:56 PM
discotx's Avatar
265/75/16's..That's what he recommended to me..as did others....after the lift no rubbing...even off road with the rear wheels stuffed in well.....I went with BFG MTs....
Old Jan 4, 2008 | 10:00 AM
I run 265's, but it will require a lift and you will loose just short of 2 MPG.
My 2 cents worth.
Old Jan 4, 2008 | 08:40 PM
LRDISCO's Avatar
NO BIGGER than 29.10" without a lift thats how big my interco trxus a/t's are and they barely make it and rub a little when i turn.
Alex_M
Nov 22, 2018 12:53 AM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
bikingteacher
Sep 16, 2010 06:44 PM
RoverDude71
Mar 2, 2009 11:03 AM
