Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Mounting Tires
Old Jan 23, 2012 | 06:51 PM
shanechevelle's Avatar
Default Mounting Tires
Now I know some of you have mounted more tires then I...
I have been doing it for some time on many different types of changers...
BUT EVERY time I have to change one of these tires It NEVER EVER EVER goes on smoothly...
I just took a goodyear off, took me about 45 minutes...
Now Ive been seating and reseating the new yokohama HT/S and the thing gets hung up on the little bump on the inside. I can hear the cords stretching, and the bead is really soapy...but the bead just wont go over that bump.
Any secrets I can add to my black book? I tried all kinds of tricks...
Old Jan 24, 2012 | 03:27 PM
Are you talking about having a tire switched at a tire store or doing it your self?
There is nothing unusual with a Rover wheel and they except all tire designs.
Old Jan 25, 2012 | 02:24 PM
Myself...at our resto shop...
The problem is...
The Yokohama HT/S bead is really tight.
The L R rim has a 1/2 inch rise on the inside of the rim. Perhaps you have seen the rise? Its about an inch across and goes around the whole rim.
3/4 of the tire seats onto the rim, but then the other 1/4 gets hung up on the lip of the rise and after 60lbs of air (20 pounds to many for seating a bead) it still doesnt seat.
I have to take the air out, break the bead, and reseat...3 or 4 times. When I fill the tire, I hear the cords and the rubber stretching in the tire. After 3 or 4 reseats the tire finally seats.
Yes the tire is lubed.
I looked on google images to find the inside of a LR rim but was unsuccessful..
Does any member here have a rim without a tire on it that they can upload a pic or send me a pic and I will upload it?
Old Oct 11, 2012 | 01:24 AM
glamor's Avatar
6th Gear
Make sure that should not be slipped even it is raining. Because after raining you know the mud occur...
Alex_M
Nov 22, 2018 12:53 AM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
esaycho
Mar 6, 2006 05:31 PM
langy
Aug 6, 2005 03:55 AM
