2003 Discovery 2 SE
2003 Land Rover Discovery
  • 2003 Land Rover Discovery - 2003 Discovery 2 SE - Used - VIN 12345678912345 - 190,000 Miles - 8 cyl - 4WD - Automatic - SUV - Silver - Richmond, VA 23229, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $9,500
    • OBO
  • Location Richmond, VA, 23229, USA
  • Condition Used
  • VIN 12345678912345
  • Mileage 190,000
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Silver
I am selling my 2003 Land Rover Discovery 2. It has 190k miles. It has been a great vehicle, but it’s time to move on. It has been a staple old reliable vehicle in our family. When all other cars have broken down, she has been the one to stand up and be there for us. I built her with the intentions of taking it cross country from New Zealand to Alaska, but having kids has made that trip less likely in this vehicle. So I am selling it. I probably won’t be able to fit all the good things I can say about this vehicle and what I’ve done
with it, but I will try:
4.6L V8 engine. Rebuilt at 170k miles with many new parts and modifications.
 ENGINE
o Ultima yellow top battery.
o Cooling system completely overhauled to prevent overheating.
 185 degree thermostat (10 degrees cooler than OEM).
 New aluminum cooling components installed at all hose junctions.
 New cooling hoses.
 Temperature sensor installed in line at the hottest point of the coolant.
Sensor is on the Driver’s side A-pillar and much more accurate than the on dash sensor.
 All aluminum radiator.
 New cooling fan.
 New water pump.
 Custom switch installed in center console to activate cooling fans
manually should temperatures need it.
o Engine was meticulously cleaned in every pathway and every bolt before reassembly during rebuild.
o New timing chain.
o Cylinder heads were rebuilt.
 New valves, valve seals, and push rods.
 Resurfaced at a metal shop.
 ARP head studs installed for better torque being applied to the block.
o Oil pump rebuilt with new gears.
o New power steering pump.
o New fuel injectors.
o New spark plugs/wires/coils.
o New O2 sensors all around (OEM only. This engine DOES NOT like cheap parts. I have not skimped out).
o Refilled AC refrigerant just this 2022 summer.
o NO CHECK ENGINE LIGHTS! NO 3 AMIGOS! NO XYZ SWITCH ISSUES!
o Always driven with Premium gas.
Other modifications made to the vehicle
 Interior Modifications
o Radio
 New Bluetooth/nav Android headunit
 Has a portable HDD that you can use to watch movies on over the radio screen.
 NAV is already uploaded with the entire state of VA and Points of
Interest.
 Bluetooth phone calling available.
 New speakers installed into all doors.
 New subwoofers installed into rear door.
 Backup camera installed that turns on automatically when put in reverse.
o CB Radio with Firestik antenna installed on the rear bumper.
o Power Inverter installed in the rear compartment for passengers.
o All switches, gadgets, gizmos, drawers inside WORK. You will find nothing that doesn’t work as it should.
o Fire extinguisher mounted in cargo area.
o Axe mounts installed inside the vehicle in the cargo area.
o Escape hammer mounted in ceiling of the front of the vehicle.
o Headliner removed, sanded down, and painted to match the interior to prevent future sag.
o Sunroof hoses have been drained and cleaned in the last 10k miles to prevent clogging.
o Wiring is in the headliner for a dash cam to be installed at a later time.
o AC is ice cold, heat is hot.
 I created and installed a custom filter/grate to prevent leaves and debris from clogging up the blower fan.
o New leather around shifters and parking brake.
o Cargo cover included.
o Heated front seats.
o Heated windshield.
 External Mods
o 33" General Grabber tires installed on 16" Vision wheels.
o New tie rods and steering components installed in 2020.
o Ladder installed.
o Fender flares installed.
o Wheel spacers installed for a wider stance.
o Center locking differential.
o All steel front bumper with 12,500 winch installed that has a remote and manual controller. D-links installed.
o Discovery 2 running boards refinished and installed.
o Hitch, universal tow ball, and 4 pin hookup installed.
o Modified spare tire holder to accommodate 33" tire.
o New steel rear bumper with D-links.
o Discovery 1 roof rack installed with a custom made light system mounted.
 4 Spot Lights, 2 Flood Lights. Light switch is flush on the left of the steering wheel for easy access.
o Offroad recovery ramps mounted to the passenger side outside of the roof rack.
o 2 in suspension lift installed prior to my purchase.
o 2 in body lift kit included, but not installed.
o Snorkel system has been installed, but needs final seal at the fender to be water tight.
 Preventative Maintenance
o Oil changed with new filter in the last month
 I use Valvoline VR1 20w-50. The valves love this in this engine.
o Coolant flushed and replaced when new cooling items were installed in the last 20k miles.
o Differential fluids (front and rear), transfer case fluids, and transmission fluids all changed out in the last 20k miles. New filter installed in the transmission.
o PCV valve replaced with a more sturdy metal version. Didn’t need to, no issues, but I wanted a more reliable system.
o LED Headlight bulbs installed into the HID headlamps.
I have gone ON & ON and I still keep finding things that I’ve done and how much work I have put into this vehicle. I don’t want to keep typing. I will not hesitate to say I love this car. I have
had 2 of them, and I hate to part with her. But I am ready to move on to my next project and I want her to find a loving home to go to next. I am ready to answer any questions you want, tell you any stories of trips I’ve taken her on. Please reach out.
Old Jul 15, 2022 | 10:54 AM
xargon15's Avatar
I do not have the VIN on hand right now as I am at work. I will update that over the weekend.
