2004 Discovery S - blue - a reliable, clean daily driver
2004 Land Rover Discovery
  • 2004 Land Rover Discovery - 2004 Discovery S - blue - a reliable, clean daily driver - Used - VIN SALTL19494A865218 - 8 cyl - 4WD - Automatic - SUV - Blue - Charlotte, NC 28205, United States
    Expired
    Expired
    $5,500
    • Trade
  • Location Charlotte, NC, 28205, USA
  • Condition Used
  • VIN SALTL19494A865218
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Blue
Greetings everyone,
2004 Disco  S - no sunroof - 5 seats
$5.5K - firm; if I don’t sell, this will be off-the-frame restoration
132K (owner since 107K, my daily driver for the past 5 years)
Good condition for what it is
2K oil changes
Cali / NC car - no rust
* Will post more pictures when I clean up a bit
Last 5K:
    - Magnaflow catalytic converter ($800)
    - O2 sensors ($150)
    - Coolant flush
    - Air filter
    - Rear passenger door actuator
    - Rear gate actuator
    - OME steering damper
Last 25K:
    - 265/75/16 BGF, including the spare
    - Terrafirma 2” lift
    - Front bumper
    - Top-end work: new headgaskets, camshaft, pushrods, lifters
    - Waterpump
    - Oil pump
    - Fuel pump
    - Valve cover gaskets
    - Ignition wires
    - Spark plugs
    - Fuel injectors
    - Cabin air filter
    - Rotors, pads
    - Windshield cowling
    - Windshield wiper motor
    - Battery
    - MAF sensor
    - Alpine w Bluetooth
    - Driver seatbelt tensioner (new OEM)
    - Serviceable front driveshaft
    - 180F Land Rover OEM thermostat
    - Stainless steel brake lines
What you need to make it perfect:
    - Replace the windshield - there is a small crack
    - Fix three amigos - I have the proper kit from Falconworks; not just a wiring workaround
    - Fix the dent in the lower pass rear corner
    - Replace ball joints - there are cracks in the rubber, but they function well!
Answer to common questions:
    - Yes, the AC works
    - Yes, the t-case has a tiny oil leak
    - Yes, there was a water leak in the passenger A-pillar - I think I fixed it
    - No coolant leaks
    - No engine oil leaks
Trades accepted:
    - Bitcoin USD equivalent
    - Watches - Omega Speedmaster, hesalite; Blancpain 50 Fathoms w $ going your way; Grand Seiko
    - Festool - let me know what you have
    - Technical diving stuff - rebreathers, oxygen boosters, high-end lights, scooters - you get the vibe
Old Mar 26, 2023 | 08:18 PM
gsp's Avatar
gsp
3rd Gear
pm sent
Old Mar 31, 2023 | 07:09 PM
mr. choodles's Avatar
Sold.
