2004 Discovery S - blue - a reliable, clean daily driver
For Sale2004 Land Rover Discovery
Greetings everyone,
2004 Disco S - no sunroof - 5 seats
$5.5K - firm; if I don’t sell, this will be off-the-frame restoration
132K (owner since 107K, my daily driver for the past 5 years)
Good condition for what it is
2K oil changes
Cali / NC car - no rust
* Will post more pictures when I clean up a bit
Last 5K:
- Magnaflow catalytic converter ($800)
- O2 sensors ($150)
- Coolant flush
- Air filter
- Rear passenger door actuator
- Rear gate actuator
- OME steering damper
Last 25K:
- 265/75/16 BGF, including the spare
- Terrafirma 2” lift
- Front bumper
- Top-end work: new headgaskets, camshaft, pushrods, lifters
- Waterpump
- Oil pump
- Fuel pump
- Valve cover gaskets
- Ignition wires
- Spark plugs
- Fuel injectors
- Cabin air filter
- Rotors, pads
- Windshield cowling
- Windshield wiper motor
- Battery
- MAF sensor
- Alpine w Bluetooth
- Driver seatbelt tensioner (new OEM)
- Serviceable front driveshaft
- 180F Land Rover OEM thermostat
- Stainless steel brake lines
What you need to make it perfect:
- Replace the windshield - there is a small crack
- Fix three amigos - I have the proper kit from Falconworks; not just a wiring workaround
- Fix the dent in the lower pass rear corner
- Replace ball joints - there are cracks in the rubber, but they function well!
Answer to common questions:
- Yes, the AC works
- Yes, the t-case has a tiny oil leak
- Yes, there was a water leak in the passenger A-pillar - I think I fixed it
- No coolant leaks
- No engine oil leaks
Trades accepted:
- Bitcoin USD equivalent
- Watches - Omega Speedmaster, hesalite; Blancpain 50 Fathoms w $ going your way; Grand Seiko
- Festool - let me know what you have
- Technical diving stuff - rebreathers, oxygen boosters, high-end lights, scooters - you get the vibe
