"Red Velvet" Bespoke Brembo Brake Caliper/Rotor Setup - L405, L462, L494
Brakes
  • Brakes - "Red Velvet" Bespoke Brembo Brake Caliper/Rotor Setup - L405, L462, L494 - Used - 2013 to 2021 Land Rover Range Rover - 2014 to 2021 Land Rover Range Rover Sport - 2018 to 2021 Land Rover Discovery - Brecksville, OH 44141, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $1
  • Location Brecksville, OH, 44141, USA
  • Condition Used
  • Compatibility
Make Model Year
Land Rover Range Rover 2013 - 2021
Land Rover Range Rover Sport 2014 - 2021
Land Rover Discovery 2018 - 2021
I can't help but feel like the standard red Brembo setup only serves to commoditize the look of what is otherwise a bad*ss ride.  Instead of getting away from red altogether, I challenged myself to sex it up a bit.  To my satisfaction, the coating came out ridiculous.  A matte anodized scarlet, with the logo sprayed on and buried in more matte clear.  Can't feel a thing.  To say it's a meticulous motif might be understating it.    Read on for the tech/details .. . .. and mail me for better response times.
Application:
  • 2013-Present Range Rover (L405)
  • 2014-Present Range Rover Sport (L494)
  • 2017-Present Land Rover Discovery (L462) - Upgrade from OE options
Front:
  • Calipers: *NEW* - 2x OEM Brembo P/N: LR049115 + LR049117 - 6-piston fixed caliper with a Bespoke matte anodized high-temperature ceramic urethane finish - mold seams shaved, bearing surfaces masked, custom artwork painted on and sealed in.
  • Rotors: *NEW* - 2x Brembo P/N: 09.A773.11 - 380x32mm -- Custom dimpled with the Brembo GT-style 32 row pattern, factory UV coating left intact and top-coated with satin black high-temp catalyzed urethane for additional protection and aesthetic value.
  • Pads: *NEW* - Pair Powerstop P/N: 16-1426 - Ceramic low dust/low noise street pad
Rear:
  • Calipers: *REFINISHED* - 2x OEM TRW P/N: LR063291 + LR063293 - Calipers with integral e-brake - Bespoke matte anodized high-temperature ceramic urethane finish - mold seams shaved, bearing surfaces masked, logo painted on custom hand-made logo/accessory plates recessed into caliper body and epoxied in place.
  • Electric Actuators*NEW* - 2x OEM P/N: LR036573 (3-Pin, L405) or LR102237 (2-Pin, L462, L494) parking brake motors
  • Rotors: *NEW* - 2x Brembo P/N: 09.B504.11 - 365x25mm -- Custom dimpled with matching Brembo GT-style 32 row pattern, factory UV coating left intact and top-coated with satin black high-temp catalyzed urethane for additional protection and aesthetic value.
  • Pads: *NEW* - Pair Powerstop P/N: 16-1692 Ceramic low dust/low noise street pad
Notes:
  1. Selling as complete package only – This is the only one if its kind.
  2. Make sure your wheels will clear the front 6-piston units. Dust shields may need trimmed or removed to fit the massive front binders.
  3. Accessory items like lines, sensors, and fluids are not pictured or provided.
  4. **Ensure that your installer (if you're not a wrench) will install aftermarket/custom parts
  5.
Old Apr 1, 2021 | 08:20 AM
CG1's Avatar
CG1
sold.
