"Red Velvet" Bespoke Brembo Brake Caliper/Rotor Setup - L405, L462, L494
For SaleBrakes
I can't help but feel like the standard red Brembo setup only serves to commoditize the look of what is otherwise a bad*ss ride. Instead of getting away from red altogether, I challenged myself to sex it up a bit. To my satisfaction, the coating came out ridiculous. A matte anodized scarlet, with the logo sprayed on and buried in more matte clear. Can't feel a thing. To say it's a meticulous motif might be understating it. Read on for the tech/details .. . .. and mail me for better response times.
Application:
- 2013-Present Range Rover (L405)
- 2014-Present Range Rover Sport (L494)
- 2017-Present Land Rover Discovery (L462) - Upgrade from OE options
Front:
- Calipers: *NEW* - 2x OEM Brembo P/N: LR049115 + LR049117 - 6-piston fixed caliper with a Bespoke matte anodized high-temperature ceramic urethane finish - mold seams shaved, bearing surfaces masked, custom artwork painted on and sealed in.
- Rotors: *NEW* - 2x Brembo P/N: 09.A773.11 - 380x32mm -- Custom dimpled with the Brembo GT-style 32 row pattern, factory UV coating left intact and top-coated with satin black high-temp catalyzed urethane for additional protection and aesthetic value.
- Pads: *NEW* - Pair Powerstop P/N: 16-1426 - Ceramic low dust/low noise street pad
Rear:
- Calipers: *REFINISHED* - 2x OEM TRW P/N: LR063291 + LR063293 - Calipers with integral e-brake - Bespoke matte anodized high-temperature ceramic urethane finish - mold seams shaved, bearing surfaces masked, logo painted on custom hand-made logo/accessory plates recessed into caliper body and epoxied in place.
- Electric Actuators: *NEW* - 2x OEM P/N: LR036573 (3-Pin, L405) or LR102237 (2-Pin, L462, L494) parking brake motors
- Rotors: *NEW* - 2x Brembo P/N: 09.B504.11 - 365x25mm -- Custom dimpled with matching Brembo GT-style 32 row pattern, factory UV coating left intact and top-coated with satin black high-temp catalyzed urethane for additional protection and aesthetic value.
- Pads: *NEW* - Pair Powerstop P/N: 16-1692 Ceramic low dust/low noise street pad
Notes:
- Selling as complete package only – This is the only one if its kind.
- Make sure your wheels will clear the front 6-piston units. Dust shields may need trimmed or removed to fit the massive front binders.
- Accessory items like lines, sensors, and fluids are not pictured or provided.
- **Ensure that your installer (if you're not a wrench) will install aftermarket/custom parts
