Very well maintained 08 LR3 HSE w A bar & AT tires
2008 Land Rover LR3
  • 2008 Land Rover LR3 - Very well maintained 08 LR3 HSE w A bar & AT tires - Used - VIN SALAG254X8A466489 - 165,000 Miles - 8 cyl - AWD - Automatic - SUV - Gray - Atlanta, GA 30030, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    $6,900
  • Location Atlanta, GA, 30030, USA
  • Condition Used
  • VIN SALAG254X8A466489
  • Mileage 165,000
  • Engine 8 cyl
  • Drive Type AWD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Gray
Hey everyone, I'm selling my ridiculously well maintained🙂 2008 LR3 HSE with the 4.4L V8 and 165k miles. I'm the third owner and have had it for about 50k miles. $7k or best offer, in Atlanta, GA. Almost every system has been gone over and/or replaced. No rust. Clean title and recently passed GA emissions. Read on for details.
Major options: factory A bar with auxillary lights (switched on the dash), running boards, factory dash wood trim and the upgraded leather option. 265/60/18 Falken Wild Peak AT3 AT tires with less than 10k miles on them, on 18" SE wheels, so much better tire selection than for the 19" HSE wheels. Frame mount Curt tow hitch and Tekonsha brake controller included (towed our medium size travel trailer about a half dozen times with it).
Am selling to make room for my next project. This is my third LR3 - so far! Read on for the extensive, proactive maintenance that I've done.
So this has been my hobby for the last few years obviously 🙂
Mechanical-all new front suspension/steering/brakes: including lower and upper control arms & ball joints; steering rack, lines, pump and fluid; tie rods and ends, sway bar bushings, new front discs/pads/brake fluid
-recent front air struts and compressor-new radiator, thermostat & housing, water pump and overflow resorvoir
-recent new AC compressor and alternator-recently serviced transmission fluid, new filter and pan
-low mileage front diff installed recently (old one had a noisy bearing)
-recent plugs, coils, flow matched refurbed fuel injectors (and throttle body cleaning)
-new AGM battery, negative battery cable, and all engine grounds checked, cleaned, and treated with corrosion inhibiter-new oil cooler gasket to stop a slow oil drip-recently replaced AC compressor and new alternator
-new EGR valve and PCV valve
-new O2 sensors and cats (theft replacement)
-sunroof drains cleared and checked, cabin air intake water deflector installed under windshield cowl, and A pillar trim sealed underneath also (most common water ingress points)
-Always 5k mile full synthetic oil changes, fresh diff oil and tcase fluid
Cosmetics:
-just refinished the front A bar & ceramic coating restored the exterior black plastic (fender flares, windshield cowl, running boards etc), polished/waxed paint
-carpet and rest of interior not perfect of course, but pretty good
-Coverlay dash cover installed since it had the typical cracks in the dash, pretty good factory look
Only issue I know of is that it has an occasional extended crank. Maybe 1 out of 10 times it will take 5+ seconds to start instead of firing up instantly. When this happens a pedal once to the floor to flood clear, then release, and it starts right up, which makes me think it's a fuel injector getting stuck open sometimes, but haven't tried to swap it out yet since it's intermittent and never been a problem for me. I will include the original injectors with the sale if I don't get around to doing it myself. In any case it always starts, runs great and nothing has changed for the last 5 or 10k miles or so.
Gets 19 mpg highway typically, and the usual 12-14 city mpg. Could also use fresh rear brakes sometime soon. Will include those parts if I don't install them myself before the sale.
Message or post here if you have any questions.
Really not sure what to ask for it but $7k will work. Best offer wins. If needed, buyer arranges shipping, but I can assist if needed.
Old Nov 8, 2022 | 01:38 PM
tracyc's Avatar
I have posted this on Tred also, to facilitate the sale. Here is the link: tred.co/W6tK
Old Nov 13, 2022 | 02:32 PM
tracyc's Avatar
Now SOLD
