“Front Knuckle Extender (LR136701)” Purpose??
Old Jun 1, 2024 | 02:09 PM
DefenderSl*t's Avatar
Default “Front Knuckle Extender (LR136701)” Purpose??
I’ve recently done some adjustments to get the 18” factory steel wheel to fit my P400 90. After much research I thought I had everything right, until when mounting tires I discovered this knuckle extender is preventing fronts from fitting.
Here is the part with diagram and explanation (https://www.scuderiacarparts.com/part/1123887/landrover/lr136701/extension-front-knuckle.html)
I cannot for the life of me figure out what this metal bit, with its small weak bolt, is for. I have since removed them to allow the steelies to fit and nothing feels different.
Anyone have knowledge of this?
Old Jun 1, 2024 | 02:28 PM
TeddyG's Avatar
IIRC it's mud scraper
Old Jun 2, 2024 | 09:25 AM
Racer20's Avatar
Probably a mass damper. It purpose is likely to reduce a very specific noise or vibration problem. It may or may not be something you notice.
Old Jun 2, 2024 | 12:35 PM
TeddyG's Avatar
Old Jun 2, 2024 | 01:44 PM
gurka01's Avatar
Lots of discussions on this in past threads. It is a mud scraper and I believe it is only on the 20s but I could be wrong on that. I took it off as well to fit my 18s
Old Jun 2, 2024 | 03:04 PM
wlindsey@gmail.com's Avatar
Dropping my P400 off at the shop tomorrow to have the OEM white 18” steels fitted. Someone else posted they had done this on a P400 … requires several changes to get them to fit including removal of the front mud scraper. Did you change the rear calipers or just do the grind?
Old Jun 2, 2024 | 09:56 PM
gurka01's Avatar
I put on the Tuffant alloys not steel. I heard others that have done it though with spacers. Would love to hear how it turns out. For the rears I ended up grinding.
Old Jun 2, 2024 | 11:12 PM
GavinC's Avatar
You'll need to swap the calipers, spacers and grind the new calipers too. The OEM offset +41.5 is a big problem. The alloys that work have offsets in the 20s. Tuffant Simpson ar 27, Kimberley are 29. Dakar Zero are 25.
Front mud scraper comes off in a jiffy. But fronts will still need spacers for steelies.
All been tried and tested.
LR disco 5
Jun 14, 2021 10:07 AM
Groucho123
Oct 25, 2018 04:34 PM
old gold
Jul 9, 2009 10:14 AM
Street Wolf
Dec 29, 2008 10:08 PM
STLROVER1981
Tires
Jul 17, 2007 12:20 PM
