110 Defender P300 first oil change
Thanks, useful info for me I use Castrol Edge too. The first oil change in a new car is always memorable. Since you always need to use oil of high-quality brands and only according to the instructions, I have already dealt with old models of the Range Rover and I know how to change the oil myself. I use 5W-30 oil, on this site https://davesoilchange.com/5w-30-oil-guide/ I looked at the best oils of this marking, you can choose the one that suits you.
Has anyone had issues removing the oil filter cover? I've been using a 14 flute socket but I can't seem to get the over off. This is the vehicle's second oil change, so I wonder if it was over tightened by the dealer? Anyone experience this before?
I have. I performed my second oil change last week. I also did the first service. I know I hand tightened the filter cover after the first service but it was impossible for me to remove the cover with my hand this time. I had to order a 14 flute oil filter wrench to get it off.
I have been changing my own oil every 5K miles for the past 70K. I have always used the socket-type tool mentioned above.
The threads are plastic and are fine. They do not require a large amount of force when unseating or installing the cap.
The mating thread connection is difficult to start accurately, I recall. Once you get the cap off, I advise you check both threads for cross-threading. A ham-handed mechanic could very easily apply a big wrench and do damage to both threading surfaces, I suspect.
I hope all goes well. Enjoy !
I'm in the USA, and I think this:
https://www.castrol.com/en_us/united...html#tab_0w-20
product sheet - https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/2024DB83077B782080258C2F003EE800/$File/wepp-ddufff.pdf
is the same thing as this this dealer oil - https://www.roverparts.com/engine/mo...VXZ2oUw4P43-tw
The former can be purchased at Walmart for $26.00 for a 5 quart jug.
can someone check me here?
