110 Ride Height shown as 66.8”s???
Old May 1, 2021 | 10:46 AM
Steven Schorer's Avatar
Default 110 Ride Height shown as 66.8”s???
In the Defender brochure, Standard Ride Height is 66.8”s. Is this correct as everything I see has the defender height at 77”s. Is this a lowered position? Is ride height different the height of vehicle? I am trying to fit in a parking garage at 76”s so this is a go/no-go kind of thing
Old May 1, 2021 | 11:42 AM
carlmuck's Avatar
"normal" height in my manual is 77.5" (1970 mm) from ground to top of the shark fin on level ground. "Access" height is 1.6" (40mm) less. So 76" will be very tight. If you run the tires at "light load" pressures you may gain a fraction of an inch.
Old May 1, 2021 | 02:34 PM
Default Do we know what “Standard Ride Height” of 66.8”s mean in spec sheet?
Can you Lower the car with Air Suspension? How Low?
Old May 1, 2021 | 05:02 PM
carlmuck's Avatar
The page that you've cut off lists the "Standard Ride Height" as 77.7" with coil suspension and 77.5" with air suspension for the 90.
Yes air suspension has several ride heights, "Access Height" is 40mm (1.6") lower than "standard" (75.9") Off road modes can be as much as 5.8" higher. (page 37 of that brochure)
The 66.8" is a misprint. The 110 ride heights are the same as the 90.
Old May 1, 2021 | 06:38 PM
Default Thanks all. I learned from another dealer it’s a misprint
[QUOTE=carlmuck;772291]The page that you've cut off lists the "Standard Ride Height" as 77.7" with coil suspension and 77.5" with air suspension for the 90.
The 66.8" is a misprint. The 110 ride heights are the same as the 90.[/QUOT
Thanks as well. I’m good!
Hayseed_D5
Jun 27, 2021 05:59 PM
2020ffender
May 11, 2021 10:00 AM
RSNSG4
Oct 27, 2020 05:18 AM
Curtis Hudson
Nov 29, 2017 07:38 PM
Manicoti
Jan 23, 2011 09:22 AM
