18" Rims that work with P400
Old Jul 30, 2021 | 04:02 PM
p010sp0rt8's Avatar
Originally Posted by NoGaBiker
Funny thing is, when I bought 16" wheels for dedicated offroad tires for my JK Wrangler they wouldn't fit over the front calipers by a tiny amount. No fancy caliper swap for me -- got out the pneumatic die grinder and took off the corner that was rubbing till it wasn't rubbing anymore. Hit it with some high-temp paint, done.
I suppose JLR would repo the Defender if I did that?
Lol.. i would do the caliper swap as well but i have no interest in giving the dealership any reason to not fix parts of the car. Even when i brought the car in to show them the taillight issue they suggested it was my PPF installers fault and they could've messed something up
Old Aug 31, 2021 | 10:00 AM
DonMitsu's Avatar
My 18" TuffAnt wheels and new rear calipers are due to arrive today! Tomorrow I will have LT265/70R18 K02s wrapped around an 18" wheel! After an unimpressive off road performance of the Factory Wrangler Adventure tires that ended in me blowing out a side wall, I'm very excited to get a proper sized wheel and tire.
Old Sep 3, 2021 | 10:32 AM
DonMitsu's Avatar
Thank you to Lucky8 for coming up with a relatively easy solution to putting 18" wheels on a P400!
Old Sep 3, 2021 | 03:56 PM
D-Fens's Avatar
Do you notice any different in how it brakes (or how the brakes "feel") with the calipers swapped? This is one change I'm seriously considering.
Old Sep 3, 2021 | 10:32 PM
GavinC's Avatar
Looks excellent.
Was the swap as smooth sailing as billed. Any issues or headaches?
The 265/70/18 is 32.6" Any lift needed for these boots and their extra 0.3" radius.?
Old Sep 4, 2021 | 10:36 AM
DonMitsu's Avatar
The brakes feel exactly the same. the rear calipers use the same pad, have an identical piston and connections. It just allows the TuffAnt wheel enough clearance to mount the wheel. The clearance is a bit tight, so you have to pay a little more attention to where you place wheel weights when balancing your tires.
Old Sep 4, 2021 | 10:37 AM
DonMitsu's Avatar
Originally Posted by GavinC
Looks excellent.
I have the Johnson Rods 1 1/2" lift. Even in access mode there is no rubbing whatsoever, but I couldn't say if that's because of the lift rods or not.
Old Sep 4, 2021 | 11:21 AM
GavinC's Avatar
No worries
Thanks for the info
carid
Appearance & Camping Set Ups
Dec 12, 2014 07:56 AM
NORTHERNMAN
Dec 8, 2009 08:49 AM
disco ben
Apr 5, 2009 01:37 PM
Indianarvergal
Dec 28, 2008 10:56 AM
Indianarvergal
Nov 16, 2008 08:08 AM
