2020 110 HSE-Persistent Interior Creaking Sound
Old Oct 8, 2021 | 07:35 AM
Virginiablast's Avatar
5th Gear
Default 2020 110 HSE-Persistent Interior Creaking Sound
Well...I approach my whit's end. 7000 miles. In August, after a trip to the dealer, and on a 106 degree day, a loud, noticeable creaking sound started to take over the cabin. It almost sounds like a moderate rain hitting the car---save for the fact that there is no rain. The sound was hit or miss for a while, and is now there all the time at speeds under 35mph. I've had the wife drive the car, and I've sat in all the seats to see where the noise is coming from. It seems to come from the tops of the doors on all sides and could even be described as sound like a crinkling sound. Interestingly, I applied pressure to the black molded pieces on the rear passenger windows...and it stopped back there. Of all pathetic things, I took an expandable shower rod and put it up across the back seat...applying pressure evenly to those areas...and the sound was reduced quite a bit. Not that you want to drive around an $80k car with a shower rod in it...
Sound has now gotten worse along front doors. There seems to be some odd interaction between the rubber gaskets in the door that might be making the noise. If I press on the top of the window or black trim from the outside, the car makes the same creaking/crinkling/squishing noise. I've applied a high end dressing to the rubber everywhere...and it might have helped a touch, but not much at all. For now driving around sounds like a squeak box, and like the inside is going to fall part.
Any thoughts? THANKS!
Old Oct 8, 2021 | 08:02 AM
_Allegedly's Avatar
You mention trying a dressing already so my apologies if this is the one you used but Gummi Pflege is known to fix most of these issues. It absorbs and causes the rubber to swell, increasing pressure against the door and frame.
I've used it successfully in the past.
Old Oct 8, 2021 | 08:16 AM
GrouseK9's Avatar
Just a lateral thought: Do you have a roof rack? If so grab all six feet (one at a time…) and shake them to check to make sure they aren’t loose.
Old Oct 8, 2021 | 11:34 AM
Sa.hib's Avatar
I am facing very same issues on my X-Dynamic P400 HSE (less than 5000km driven). Creaking sound, mainly from the top trim (leather) of the door when driving on uneven surface or with just a minor bumps on it ... with the low (20 - 30kph) speed.
I believe the only way to get rid of it, is to have the interior (specially the doors) being professionally sound isolated by the specialist.
Old Oct 8, 2021 | 12:41 PM
5th Gear
No, no roof rack. But thanks!
Old Oct 8, 2021 | 12:44 PM
5th Gear
Thanks so much. Refreshing to know someone else is dealing with it (I guess). This is a new one for me--where does one go for professional sound insulation? Hard to believe that would be required for a car like of this price tag. I can live with all the usual LR bits and baubles, but this one really bugs me!
Old Oct 8, 2021 | 12:58 PM
Sa.hib's Avatar
Old Oct 8, 2021 | 01:27 PM
Muppetry's Avatar
It's hard to know whether there is a single or multiple causes with different vehicles. On mine it is clearly originating between the top (outermost) rubber seal on the doors and the edge of the door. Pressing on the top of the door from outside replicates it, and even a very thin smear of silicone lubricant between the edge of the door and that rubber seal almost completely silences it.
Old Oct 8, 2021 | 01:35 PM
_Allegedly's Avatar
Originally Posted by Muppetry
...very thin smear of silicone lubricant between the edge of the door and that rubber seal almost completely silences it.
Gummi Pflege FTW
Old Oct 8, 2021 | 01:48 PM
Muppetry's Avatar
Gummi Pflege FTW
I've seen that product mentioned a few times. Have you used it for this specific issue, or is it just a general recommendation?
