2020 110 HSE-Persistent Interior Creaking Sound
_Allegedly (10-08-2021)
Over time the rubber loses moisture which causes it to shrink a little. When it shrinks, it gets less tight between the gaps which allows a little movement. The movement makes the squeaky.
Gummy Pflege absorbs in and replaces the moisture which swells the gasket and gives that nice tight fit back.
I first used it when a BMW service advisor gave me half a bottle because I couldn't wait to have it done at the shop. They've specified it in their TSB's over the years.
I've used Shin Etsu too. It's the Japanese/Honda version and you're going to meet people who will fight you if you say one is better.
Oh yes, on BMW's and Mercs. It's legit.
https://www.amazon.com/Honda-Genuine-Shin-Etsu-Grease/dp/B006Z9TZ9M
It also smells great and gives a nice 'detailed' look.
I can't say for sure it will fix this guys exact issue because it might not actually be the seals. It is a Land Rover after all so anything goes. I will say it has fixed similar annoying squeaks in 4 or 5 cars for me over the years.
He did say "holding the door closed" helps. Sounds like that helps close the rubber gap which is what this does.
I hear you. Supposedly silicone oil eventually cracks the rubber (who knows?) and Gummy is water/alcohol based so it feeds rather than coats.
I've heard that about rubber and silicone oil before, but it doesn't make much sense from a materials perspective. Silicone oil is almost entirely inert, and is often used to lubricate rubber gaskets. I'll get some of the Gummy and try that if/when the silicone cure wears off.
Sometimes it'll drive you bananas and you have to just keep working at it. I had a BMW once that had double seals and I just kept trying until I found this one spot on the outside rear trim.
https://www.tesladiygeek.com/2020/02/stopping-window-squeaks-and-noises-with.html?m=1
GrouseK9 (10-10-2021)
