2021 Base Radio
The standard six-speaker, 180w stereo is awful. I had a loaner with it and it was so bad, I couldn't listen to music. It is really only for listening to the news or podcasts. I have the mid-tier 11-speaker, 400w Meridian system on my 2021 110 S and it is pretty good, although not as good as Meridian systems in other JLR products. I believe it is possible to retrofit the Meridian system, but it is costly and would require CCF updates. You are probably better off going aftermarket.
All these audiophiles on here.
I think the base radio/ stereo is just fine and I use it all the time. Never seen the need for bangin' bass at my age.
Road noise from AT tires, and wind noise from roof rack and snorkel are going to eliminate the highs and lows from a $20,000 stereo in a proper Defender anyway
Just start with sound deadening of the doors, this only alone transforms the sound of your base audio system.
Next step, more expensive, 2ohm set from Blam or Focal.
I'am happy with my base sound for now.
https://landroverforums.com/forum/20...e7/#post829184
ficklma1 (10-12-2023)
