2022 Defender 110
Old Aug 17, 2025 | 04:52 AM
ethxrp's Avatar
Default 2022 Defender 110
I have a 2022 Defender 110. I have only had it a month and I have noticed there is a wind noise coming from the drivers side at speeds over 45mph and gets worse as speed increases. I t does have LED light bar fitted. Could this be the cause ?
Old Aug 17, 2025 | 07:56 AM
BritCars's Avatar
Yes. Very likely!
I did roof bars once and took them off due to the noise...
Old Aug 17, 2025 | 07:58 AM
wcc18999's Avatar
Very likely from the LED light bar. I would also check the A pillar as noise from the A pillar is a known issue.
Old Aug 17, 2025 | 11:07 AM
ethxrp's Avatar
Ok. Thanks for that. Do you know if the light bars are easy to remove. It’s not something i will use . It was on the vehicle when I bought it.
Old Aug 17, 2025 | 04:56 PM
wcc18999's Avatar
Hard to tell without seeing a picture. If they are mounted on the roof by the edge of the front glass, they are likely secured by 3M adhesive tape, which should not be hard to remove, just make sure you trace all the electrical wires and disconnect them. Good luck.
NikoDeGallo
Defender
Apr 21, 2025 05:34 PM
wfwalton
Oct 4, 2024 01:07 PM
wcc18999
Jun 2, 2024 09:55 PM
rcdoeshair
Dec 21, 2018 07:14 PM
lizglowark
Defender
Oct 16, 2011 10:08 PM
