2023 Defender 110 clicking noise
Hi
I bought my defender few months ago and ever since I have a clicking/ticking noise coming from the rear cargo door. The noise appears when ever I drive over a bumpy road or even braking.
took the car twice to the dealership but they were unable to identify where exactly the noise comes from.
Please share your experiences !!
I had the same issue. It sounded like plastic crinkling in the headliner behind the rear seats. I eventually solved it by spraying silicon lubricant on the exterior seal of the sunroof. The noise was coming from the interface between the sunroof and the rest of the body. I used a WD-40 silicone lubricant, but I'm sure there are other options. You don't need to open the sunroof to do this--just spray along the perimeter of the sunroof panel from the outside. Let me know if that helps!
WAFOX (07-04-2023)
I had a similar sounding noise and I isolated it to the rear hatch locking mechanism where it engaged with the body when closed. Dealer said the mechanism has the ability to be aligned which they did and that solved it. I sat in the back seat and had my wife drive the car so I could isolate. Good luck.
WAFOX (07-04-2023)
