2024 110X Wireless Charging
Old Apr 24, 2024 | 06:42 AM
Jamborick's Avatar
Default 2024 110X Wireless Charging
I’ve got a iPhone 12 Pro Max that only gets hot on the charging pad, to the point of overheating the phone. I don’t really care about getting a new phone but am willing. I am wondering if those with newer phones are still having this problem.
Old Apr 24, 2024 | 08:25 AM
NoGaBiker's Avatar
I abandoned wireless charging with the Defender (mine's a 2022 and iPhone 12). That amount of heat CAN'T be good for the phone!
Old Apr 24, 2024 | 08:28 AM
SilverSFR's Avatar
Try removing your phone cover and then charging your phone. Confirm if that makes any difference with heat generation.
Old Apr 24, 2024 | 09:47 AM
NoGaBiker's Avatar
That's all well and good, but it's far easier for me to plug in the phone to the charger wire hanging right there and stick it on the magnetic holder I have, than to remove and reinstall the cover everytime, so even if that solves the heat issue it's moot. Don't know about the OP's situation, though.
Old Apr 24, 2024 | 09:48 AM
rutiger's Avatar
I have a 2020 110X and have used the wireless charger with a iPhone 14 Pro Max and now 15 Pro Max. Same results as you. Almost no charge, just gets super hot. I gave up long ago and simply use a USB-C cable to charge.
Old Apr 24, 2024 | 10:52 AM
nashvegas's Avatar
I'm sure you *don't* want to hear this but my iPhone 15 Pro (ie the newest one) charges just fine on my wireless pad (2020 110 X model), and doesn't get overly hot. Had mine in the charger for a full day of off-roading this past weekend and it was fine.
It does charge more slowly than hooking up to USB-C.
When I first got the Defender, the wireless charging overheated the phone and was very finicky about charging/not charging/etc. LR dealer did a software & hardware update on the charging pad (to support MagSafe which I think at the time was screwing up the works on the charging pads) in 2021 that made it all fine. I would think the new ones are the new hardware/software.
Old Apr 24, 2024 | 11:20 AM
BraveSirRobin's Avatar
Old Apr 24, 2024 | 04:09 PM
POPTOPP's Avatar
I don't use a phone cover. Phone will heat up to the point of shutdown.
Old Apr 24, 2024 | 04:43 PM
Jamborick's Avatar
Mine makes no difference with the case or not.
Old Apr 30, 2024 | 04:24 PM
TSY's Avatar
TSY
Has anyone removed the OEM charge mat and replaced it with an empty tray (or one pre-wired presumably where a hardwired solution could live?)
*I have this issue - I've got a MY24 p400/110 .. after a couple of attempts (and loosing connection due to heat) I stopped using the mat.
