2024 - Rear USB C
Old Mar 2, 2024 | 08:57 AM
johhn14's Avatar
Default 2024 - Rear USB C
It looks like the newest 2024 builds have switched over to USB C in the rear seats. Haven't seen that mentioned but just offering it up as an observation...
Old Mar 2, 2024 | 11:29 AM
chuyn's Avatar
This is something I’m annoyed with. My ‘23 was missing them on delivery like many others, and when LR finally retrofit them later, it was just two USB-C as well. Older models (2020 to maybe 2021/22..?) had wiring for four outlets (and came with four outlets) but now there’s only enough for two. So we’ll always have two blanks, or if we want to add a couple 12V plugs, we need to buy aftermarket splitters
Old Mar 2, 2024 | 11:31 PM
Chris.Gio's Avatar
My 24 has the other kind…. Just USB I guess. Easy to update to usb c?
Old Mar 2, 2024 | 11:40 PM
Chris.Gio's Avatar
Never mind, found it: https://www.powerfuluk.com/collectio...-defender-l663
Old Mar 3, 2024 | 07:29 PM
nashvegas's Avatar
I bought 3 of the USBC's from Simon's site and installed 2 where they are pictured to replace useless USB A and then also replaced the in dash (in front of passenger) USB A with the 3rd USB C. A great update. I have zero devices that have USB A left and there's still one in the center should we ever need it.
I will say it might be better to take the console lid and back HVAC components apart to push the existing USB ports / power ports out from the inside instead of prying them from the outside. They are ridiculously difficult to pry out without scratching up the center console.
Old Mar 4, 2024 | 05:48 PM
SilverSFR's Avatar
I also heard that the USB-C and probably less for the USB-A are only 10-12 charge watts. So fast charging out of the USB-C might end up being just sorta fast charging. can anyone else confirm. And what happens to the charge watts if multiple USB-C or USB-A are in use at the same time? iPhone fast charge starts at 20 watts.
Old Mar 4, 2024 | 09:43 PM
Chris.Gio's Avatar
Originally Posted by SilverSFR
I also heard the the USB-C and probably less for the USB-A are only 10-12 charge watts. So fast charging out of the USB-C might end up being just sorta fast charging. can anyone else confirm. And what happens to the charge watts if multiple USB-C or USB-A are in use at the same time? iPhone fast charge starts at 20 watts.
good q, wonder how you test.
Xploit
Jun 20, 2024 10:28 AM
XRAD
Apr 27, 2021 09:37 AM
Davis31052
Nov 27, 2020 07:31 PM
jringeno
Jul 17, 2016 10:01 AM
ssssnake529
Sep 12, 2010 06:04 PM
