Is 22 wheel to 20 wheel swap possible on X without mods?
this claims it fits https://parts.landroverparamus.com/o...r133250?c=az0x
aren't all the 20's the same offset? the 5095 is also the default wheel in the configurator for the X.
webops (10-22-2021)
if you are using oem 20 inch defender wheels there shouldnt be a problem. i have a p400 hse that came with 20s. the X is basically the same car with some nicer bits here and there
usually going down to a 18 inch wheel is where you need to change the rear caliper
webops (10-22-2021)
on
The only change that I am aware of are the size of brakes from the p300 to p400 engines. So you would need to do some modification to get down to 18 inch wheels on the X, but not 20 or 19.
LRDEF2LR (04-28-2022)
I have a '22 X with 20" wheels. There should be no problem in swapping them. The brake calipers only change going from the P300 to P400.
webops (10-22-2021)
