5.0 V8 Engine Oil Question
Old May 3, 2025 | 08:04 AM
Lasallen's Avatar
Default 5.0 V8 Engine Oil Question
Does everyone run 0W20 in this engine, it just seems to be a very thin oil to provide adequate protection. I know many OEM's use this spec to meet EPA MPG requirements, but typically not the best application for longevity of the engines. Any input is appreciated
Old May 3, 2025 | 09:59 AM
Jim 90's Avatar
At least on the OCTA 4.4 V8 LR recommends 0-30.
Old May 3, 2025 | 10:23 AM
WTFChuck's Avatar
Feel free to use any oil of your choice. What may seem to be ‘very thin oil’ is the manufacturer’s recommendation. Just be prepared to jeopardize your warranty.
Old May 3, 2025 | 11:41 AM
BritCars's Avatar
Yes. If it says 0W20 in your environment then you should use that
The octa engine is a totally different engine - a BMW sourced engine. So the specs and requirements would be totally different
Old May 3, 2025 | 12:19 PM
Lasallen's Avatar
I totally understand what you are saying in regards to 0W20, warranty, and LR. But, we all know the 5.0 is being phased out due to EPA and other government emissions agendas. Many Manufacturers gravitated toward a thinner oil to try to squeeze any efficiency out of the engines that they could. I feel with that they are all sacrificing reliability and longevity. This is showing to be true with the GM and the 6.2 debacle right now. They are immediately changing from 0W20 to 0W40.
Old May 3, 2025 | 12:24 PM
wcc18999's Avatar
Stick to the OEM recommended oil viscosity.
Old May 3, 2025 | 12:35 PM
Lasallen's Avatar
Thats the easy answer, but is it right? That would be like sticking to the 15000 interval because JLR recommends that.
Old May 3, 2025 | 02:47 PM
wcc18999's Avatar
I like easy lol..As far as the recommended 15000 interval, there are different views on that subject. I change mine at least once a year. Remember, today's synthetic oils are much better that the old conventional oils. If you do a lot of off roading in dusty environments, and drive in stop and go traffic, changing the oil more frequently is recommended. But I would still go with the OEM recommended oil viscosity, however, at the end of the day it is your call and you are free to do what you desire.
acebroke1
Aug 23, 2024 03:36 PM
keninnc
LR4
Apr 30, 2024 08:45 AM
Landtastik
Mar 15, 2024 03:44 PM
Athana
May 30, 2022 08:39 PM
Bmcghan09
Apr 7, 2014 09:06 AM
