Adaptive Cruise with GAP IID?
Old 09-29-2023, 10:35 AM
GavinC's Avatar
Received 2,505 Likes on 1,016 Posts
Originally Posted by AAJR
What is this?
You can lift the vehicle using the tool. Simply tell the air suspension to change it's standard height. Up or down as needed. Affects all the height settings. Just like having a lift rod.
A rod changes the hardware and leaves the software unchanged.
The tool changes the software and leaves the hardware unchanged.
The beauty of the latter is that you can turn it on and off as needed using your phone. Just a few few quick clicks. Perfect for the likes of me who does not want to use rods for a variety of reasons and would only need a lift on rare occasions when I encounter a big obstacle.
Similar to LLAMS but without any installation or additional cost. That's what sold me on it.
You can also use it if you want to lower the Defender. Perfect for those who've sustained a cognitive brain injury challenges fitting in a garage..
Ratledge (09-30-2023)
  #22
Old 09-29-2023, 11:44 AM
stevemfr's Avatar
Originally Posted by GavinC
...You can also use it if you want to lower the Defender. Perfect for those who've sustained a cognitive brain injury challenges fitting in a garage..
  #23
Old 09-29-2023, 12:15 PM
DefenderSISU's Avatar
Default I am sold
Where can I buy this IID tool ?
  #24
Old 09-29-2023, 01:16 PM
starbai's Avatar
Bought mine from lucky8 off road, got to me quickly. no issues.
The following 2 users liked this post by starbai:
ficklma1 (10-02-2023), Ratledge (09-30-2023)
  #25
Old 09-29-2023, 02:15 PM
Default Thank you
Thanks
  #26
Old 09-29-2023, 05:47 PM
GavinC's Avatar
Or you could cut out the middleman and buy it direct from GAP Diagnostics.
  #27
Old 09-29-2023, 09:36 PM
AAJR's Avatar
Thank you. I'm one of the people who apparently sustained cognitive brain injury, as I lowered the vehicle by 20mm thinking I would get a better handling car on the freeway and on the twisty bits. Fortunately, the brain injury is reversible in my case; the car rode much worse while driving it on a 4 hour drive. Changed it back to stock the following day to continue the journey.
  #28
Old 09-30-2023, 02:07 AM
Defendit..'s Avatar
Exactly, that's when the Llams height adjuster comes in very convenient.
Just with a turn of the selector **** lower it for less body roll, more sporty drive, preferable on good smooth tarmac .
I do use it frequently.
  #29
Old 10-01-2023, 12:06 PM
ckamps's Avatar
As an alternative to waiting for the Gap IIDTool to enable activation of ACC, I’ve been researching the cost, components, and techniques needed to do the same via the JLR Pathfinder app.
if you either have experience with this alternative method and are willing to share information with the community or are interested to see if it might be a cost effective DIY option to activate ACC and other features, see this thread:
https://landroverforums.com/forum/20...er-app-118985/
The following 2 users liked this post by ckamps:
Iceman153 (10-01-2023), WAFOX (10-01-2023)
DarkyUK
02-02-2023 07:58 AM
Philip Chan
06-21-2019 11:23 PM
Oasisplayer311
05-07-2015 01:13 AM
Quick Reply: Adaptive Cruise with GAP IID?
