Advice needed for Rim offset
Old Mar 20, 2022 | 04:16 PM
  #31
Ehloo's Avatar
the width of the wheel is equally as important as the offset. what width are you running on your Vossens
Originally Posted by RR2Dfndr
Update: I just installed the Vossen HF2 20" +20 offset wheels with 275/55/20 Cooper tires. There is no rub on normal height, and a very slight rub on access height with full lock.
I highly recommend getting new wheels with this offset than installing spacers on stocks rims, which I had done for 1000 miles.
Old Mar 20, 2022 | 04:21 PM
  #32
Ehloo's Avatar
here is hood calculator to see how a new set would fit compared to your current wheels.
i have a set of custom forged wheels in order. 22x10 et 30. going to play around that 30 offset a little. it’s a very similar fitment compared to my 20x8.5 et 10
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old Mar 20, 2022 | 11:19 PM
  #33
RR2Dfndr's Avatar
9.5 inch width
Old Mar 24, 2022 | 06:47 PM
  #34
RR2Dfndr's Avatar
Default Update Vossen HF-2 20x9.5 on 275/55/20
Old Mar 24, 2022 | 10:32 PM
  #35
Ehloo's Avatar
how you liking the Cooper tires. have been researching a mild all terrain and the coopers are one of the options
Old Mar 25, 2022 | 12:14 AM
  #36
RR2Dfndr's Avatar
they ride smoothly and quietly like the wranglers.
Old Mar 25, 2022 | 07:23 AM
  #37
Quick's Avatar
Any rubbing? What’s the offset of this setup? They look great. I’ve been considering these or the HF-5 in a +35 offset.
Old Mar 25, 2022 | 01:11 PM
  #38
RR2Dfndr's Avatar
No rubbing on normal height. Ever so slight rubbing in access height with full lock- this doesn't bother me at all.
+20 offset.
Old Mar 19, 2023 | 09:13 AM
  #39
niraj555's Avatar
8th Gear
I am looking to buy the same vossen HF-5 to replace the 22" rims that came with my car. Do you mind sharing some photos? I am curious how they align with the wheel arch? I do not plan to add wheel arch extensions.
Old Mar 19, 2023 | 09:15 AM
  #40
niraj555's Avatar
8th Gear
Do you mind sharing photos of your modification? Curious on how far they align with the archs? I do not plan to add wheel arch extension and want to replace the stock 22" that came with my car.
