Any photos of Extended Black Exterior Pack?
#23
All of your trucks looks amazing!!
I'm finalizing my order for a Defender S and have a question (well I have many and I have found most of the answers in this forum - thank you)
I still am not clear regarding the Extended Black Exterior Pack - specifically on my spec will the lower black trim be gloss or matte? I am hoping gloss
Thank you in advance
Matt
Matt
#24
@MattF - This is the "Option" specs for a 2022. I believe it will be the same for 2023 except they may monkey around with the Option Codes. For some strange reason they do that between MY's.
Not sure what part of the Defender your Q is about but it appears that the Black Exterior Pack is mainly the front. The black on the lower side, I believe, is always the same black. I could be wrong though and it may be driven by trim. Also the Bright pack seems to remove it.
#25
#26
Pretty sure that almost all trims are gloss black. Many folks are disappointed because the "Extended Wheel Arch" that can be added is an unpainted matte plastic and can seriously clash. Most folks paint or have them painted gloss black, but it's a bit of a PITA. I have future plans to get the Extended Wheel Arch and will live with the mix until I figure out what I want to do down the road. Things rattling around my head with no particular enthusiasm: Rhino spray it like PowerfulUk did (I know this is going to horrify many), have it sprayed by a pro in gloss black (I don't want to go thru the effort of prepping the plastic), deal with it if I get it wrapped (I have this fantasy of a dark green with ivory top), leave it like it is & don't sweat it (I don't wash mine frequently enough to make it obvious<g>).
If you get a Defender (and not the Bright pack) that bottom line is gloss black. If it comes with OEM extended wheel arch, it will be a mix.
MattF (02-15-2022)
#27
Pretty sure that almost all trims are gloss black. Many folks are disappointed because the "Extended Wheel Arch" that can be added is an unpainted matte plastic and can seriously clash. Most folks paint or have them painted gloss black, but it's a bit of a PITA. I have future plans to get the Extended Wheel Arch and will live with the mix until I figure out what I want to do down the road. Things rattling around my head with no particular enthusiasm: Rhino spray it like PowerfulUk did (I know this is going to horrify many), have it sprayed by a pro in gloss black (I don't want to go thru the effort of prepping the plastic), deal with it if I get it wrapped (I have this fantasy of a dark green with ivory top), leave it like it is & don't sweat it (I don't wash mine frequently enough to make it obvious<g>.
https://vulkanautomotive.com
GrouseK9 (02-16-2022)
#29
Thanks as always @GrouseK9 Looking at pictures I can see where some are gloss and some are not..... I'm thinking it's dependent on the model level. I think (no evidence yet) the base models - in my case a Defender S - are not gloss when selecting the EBEP.... I've got this question into my sales rep (confidence is low).
Also does anyone happen to have a MY '23 order guide?
Thanks to all
Matt
Thanks to all
Matt
rpg123
11-11-2008 07:23 PM
RangieRovie
10-07-2008 02:36 PM
