Anyone put 33 on the 18inch rims?
Old Aug 7, 2020 | 12:50 PM
ADVAW8S's Avatar
Default Anyone put 33 on the 18inch rims?
I am starting the process of getting a list together of the changes that I will be doing when my Defender arrives. I have the P300 and wanted to 33 and wanted to see if anyone has done it yet. I really wanted to know if I need to raise the suspension up or if I can run it stock.
Old Aug 7, 2020 | 01:01 PM
venom_defender's Avatar
33" tires on 18" rims vs 20" rims will be same height. Others have confirmed 33 won't work without a lift.
Old Aug 7, 2020 | 05:48 PM
Johnson Rods's Avatar
LR Forum Vendor
It's going to be the same for 90 as it is for the 110.
Our 1.5 inch lift will allow you to fit 33" inch tires and maintain ride quality.
Your are most likely looking at a 275-70-18 which is 33.2
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Mar 30, 2021 | 11:45 AM
KyleG531's Avatar
5th Gear
@Johnson Rods any issue with rubbing given the almost 1" wider tire for the 275-70-18 (versus stock 255-70-18)? I know the 33" fits from a circumference perspective, but the width concerns me.
Old Mar 31, 2021 | 06:18 AM
Defendit..'s Avatar
Just stay at the 265/70/18. 32,6" no lift rods, no rubbing.
Old Mar 31, 2021 | 09:15 AM
ADVAW8S's Avatar
I ended up putting on 275/60R18. No rub but I don't think you can go any wider. I also put them on OEM rims and the tire store said that makes a big difference on wider tires working.
Old Mar 31, 2021 | 04:50 PM
KyleG531's Avatar
5th Gear
I like the idea of wider, but am mainly concerned with height. I'd like to go towards 33". Seems like the 265/70/18 may be the way to go assuming I can do that with stock wheels.
Old Mar 31, 2021 | 04:51 PM
KyleG531's Avatar
5th Gear
Did you put these on stock wheels? Id' like the keep the OEM steelies if possible.
Old Aug 18, 2021 | 03:38 PM
Bikman's Avatar
I bought 2022 X Dynamic SE with 22 rims and tires. I want to do some off roading but nothing crazy. What should i do, buy 22 inch AT tires or go with 20 inch rims with AT tires. My problem is that i will be stuck with 22 inch rims if i go with new 2o inch setup. Not sure if I could sell my 22 rimes and tires.
Old Aug 18, 2021 | 08:19 PM
_Allegedly's Avatar
Thank this guy for answering you question
https://landroverforums.com/forum/20...em-all-107719/
